front leveling kit
front leveling kit
just wondering what you guys think the best system to raise the front. i put a set of AIRLIFT superdutys on the back it so when i connect my trailer it wont sag, now i am thinking about getting rims and tires might go with 33 or 35 either way i think i am going to do the front leveling kit any. any ideas on which one to buy or what you think would look best 33 or 35 pics would be a plus thanks in advance
SKYNYRD when you have the trailor on with that truck it is sagging a little do you have helper bags pumped on the rear? ( are they the 1400lbs or the 6000lbs?) i just dont want my truck to sag if i do the leveling kit once i put the trailor on. thats eactly what i dont want i tow a 31 foot hauler and i am scared it will sag if i ddo a leveling kit even thuogh i have the airlift on it?
If you stay cheap like I did and get the steel ones do yourself a favor and buy shocks too
but after my experience I feel I wasted my money on the spacers I really want a Lorenze spring kit 550 bucks or so and it takes the same amount of work to install I think your kidneys will thank you
The Kore leveling kit is 785 I believe. If you are looking for more than a leveling kit Kore makes the Recon (1580). If this is the route you want to go check out Carli, Lorenz, and Thuren as well.
I'm getting the Lorenz kit myself.
W/steel spacers, you are not changing spring compression/decompression/length/lbs. per anything. It will be the same as stock ride unless factory shocks are hitting full extension on the upward travel. Other than if that happens, it is dynamically the exact same thing.
sgtdiesel
25
Jun 26, 2012 02:37 PM
PourinDiesel
15
Nov 8, 2004 10:12 PM
DanTana
Aug 12, 2004 11:54 AM
