Flux Question, or not!!!!
Old Apr 13, 2009 | 06:03 PM
coreydr2003's Avatar
I have a frreind of mine that has an 06, with flux 4.3s, stg3 floor it pump, running TNT-R with twins. Ok here is the question. Just a few days ago he popped the head gasket. Thats not the problem. problem is when they pulled the head, there was fuel in every cylinder. More on #6 and #5 then the others..... Is this a question? having fuel in the bowls like that? Truck starts just fine. Injectors have only been in for a few hundred miles. Maybe Don will help us out.............
Old Apr 13, 2009 | 06:55 PM
Don M's Avatar
DTR Advertiser
It drops into some cylinders when the injectors are pulled out of the head.
The return circuit drilling in the head is full of fuel. It has to go somewhere. When injectors are pulled, many shops suck the fuel out of the piston bowls with a turkey baster or something similar to avoid lots of smoke on start-up.
Old Apr 13, 2009 | 08:16 PM
lmills's Avatar
Corey, that is basically the same answer I gave him. He should be good to go.
Old Apr 13, 2009 | 08:38 PM
I can always count on you Don By the way. I had the chance to drive that cam, and the bad ace F 5s........ WOW....... I got to hand it to you man. This thing Rocks...........
lmills Corey, that is basically the same answer I gave him. He should be good to go.
Thats great to hear. I know what he is goin threw. I just had a head gasket problem myself. With TS 3 weeks out. Its coming down to the wire... Thanks guys.........
Old Apr 13, 2009 | 10:17 PM
44's n 454's Avatar
sorry to hijack but i had wicked 150hp tips and could make 70lbs of boost with the rail pressure under 20k and had my stick repaired (2 bad solinoids and 3 had high return rate) and don made them into 3.8's and didnt change anything and it will only make 60-62lbs of boost any ideas??? Don?
i put springs in with the new flux but shouldnt have anything to do with the lower boost with bigger sticks?
Old Apr 14, 2009 | 06:23 AM
homewrecker's Avatar
Do you have anything done to the cp-3 to help maintain RP?
Old Apr 14, 2009 | 10:16 AM
44's n 454's Avatar
I got wicked diesels stage 3.
Old Apr 14, 2009 | 11:38 AM
O.T's Avatar
O.T
Mark, Do you have your rail capped? If not have you checked your relief valve/
Old Apr 14, 2009 | 11:57 AM
44's n 454's Avatar
Yes i got it capped. i might go with a dual ppe kit i can get one real cheap
Old Apr 14, 2009 | 01:07 PM
O.T's Avatar
O.T
Well you cannot go wrong with duals. Any luck with some road test readings?
Rob
Old Apr 14, 2009 | 01:54 PM
bigd450's Avatar
Going off of what Marco says about timing on the Smarty. "A more advanced timing will typically produce less boost than a more retarded one but that does not mean that the more advanced timing provides less power."
Is it possible with the bad solenoids and leaky injectors, that it was retarding the timing but actually producing more boost? Cause going from leaky, bad solenoids, 150hp injectors that could not hold rail pressure do to the high return rate, would make 70psi. To flux 3.8's that can now hold 25k rail pressure but only produce ~60psi. This is without changing anything even using the same Smarty SW. Checked for boost leaks used diffrent gauges and everything seems to be in check.
There is no comparison who's injector runs cleaner though.
I know there's more to HP then just the amount of boost but just tying to track things down one step at a time to get her dialed in.
bradler
Feb 18, 2009 12:43 PM
OldSmokey
19
Mar 26, 2008 05:11 PM
metal_miner
52
Jun 23, 2007 02:52 PM
O.T
May 30, 2007 08:55 PM
MoparRiggan
Jan 10, 2007 03:31 PM
