Flux F1 or F2 injectors.....
Flux F1 or F2 injectors for a stock truck. Any body have them. About ready to chunk the factory ones and put in a real set of sticks. Which ones will work on my truck in signature and do you have to send your existing ones back or do they just charge a core charge? Don't care if I up the power just want a quality set of sticks that were put together right.
Just curious, Why do you think you need sticks? The stock ones seem to be holding up well to alot of hp. I've had no problems with my stockers. When I get a set they will be Don's. For your truck I would say Flux 1's would be plenty.
The only reason I want them is because of the stockers. I have had every problem that has been posted on this board except the injectors. CP3 leak, LP problem, breather vents on fuel tank open,and A/C issues. I just don't want to have a crank case full of diesel and be hours from the house. I don't react well to break downs. May be a dent in one of the front fenders from me kicking the crap out of it and calling it every dirty name in the book if ya know what I mean.
DonM, will ensure your injectors are operating as intended and then he puts on a set of nozzles that are most likely edm'd, extrude honed, and flow matched. The nozzles are usually blanks with no holes in them so that he can pick the size of hole, location, spray angle, etc. The metal he uses in his nozzles are suppose to be of a higher grade to withstand higher pressures than stock.....but the injector body is yours so if it is already roached he might be able to fix them otherwise he can't perform miracles. Don just did a set of Hellfires for my truck and my cores were I I remans ..... some dating back to 1999....He didn't think much of them when he got them but he got them running to spec and I didn't get a repair bill... Thanks Don. Sorry to be vague with the maybe's and probably's but Don keeps his methods pretty quiet. ks
I just put a II stage 2 CP3 and a set of Don M FLUX 2s on my truck. I wanted to see what the pump and injectors would do alone! I turned all my electronics off and made 100HP and 250lbs over stock
IMO I would buy a set from Don M, no IFS ANDS OR BUTS.
CRIS
CRIS
bradler
Feb 18, 2009 12:43 PM
OldSmokey
19
Mar 26, 2008 05:11 PM
metal_miner
52
Jun 23, 2007 02:52 PM
O.T
May 30, 2007 08:55 PM
MoparRiggan
Jan 10, 2007 03:31 PM
