Flux 2, stage 2 cp3, single turbo=
Old May 14, 2007 | 11:35 PM
O.T's Avatar
O.T
how much hp on a mustang dyno. In theory one would venture out and say 400hp <am i close?>
Then add a set of twins and a Smarty and shoot for 550?
My numbers are listed below.
Input would be helpful in understanding under 5
onetun
Old May 14, 2007 | 11:39 PM
bigredBCS's Avatar
onetun
youre saying all of that stuff would equal 400ish??
i would think more cuz i did 396 with a jucie on the 60 horse setting
WUnderwood's Avatar
what single turbo do you want to run?
you can do almost 600 hp with the stock injecors and cp3 and good tuning
hope this helps
Old May 14, 2007 | 11:42 PM
O.T's Avatar
O.T
hope this helps
OK thats where I have a hard time make 600 with good tuning............darn I can only make 491. see my mods listed below
Old May 14, 2007 | 11:46 PM
tbarbee1's Avatar
You'll have to find the thread but Mr Mills made 613hp uncorrected with a set of PDR twins tuning and stock injectors.
Old May 14, 2007 | 11:48 PM
WUnderwood's Avatar
what are the BD twins rated at hp wise? 550 hp max, right?
Old May 15, 2007 | 12:01 AM
O.T's Avatar
O.T
Advertised as 575
Old May 15, 2007 | 12:03 AM
WUnderwood's Avatar
what are your EGTs looking like on the dyno?
Old May 15, 2007 | 12:08 AM
tbarbee1's Avatar
Heres the thread I mentioned earlier
https://www.dieseltruckresource.com/...d.php?t=148435
Old May 15, 2007 | 12:15 AM
Pack Mule's Avatar
491 doesn't sound right to me, but i'm not the smartest by no means. i put down 501 stock turbo, clutch, fuel system. all i have is crazy larry, pressure box, and a brute force intake. and i know my 20" wheels hurt me some, that and being a megacab.
Old May 15, 2007 | 12:21 AM
O.T's Avatar
O.T
Hold on,, are you saying tire/wheel size effects the results.......Dude I'm running 37" m/t
Looks like more than a Smarty to roll into the fives
Old May 15, 2007 | 04:44 AM
94ttss's Avatar
I made 616hp with that setup, my egt's just touched 1400 on the dyno.
Old May 15, 2007 | 06:42 AM
RyeThomas's Avatar
Winner winner chicken dinner!
You dynoed your truck once at one place, take it somewhere else and try again. I have heard of people running the same set up in 2 different places and being close to 100hp off. I still think your rail pressure was low and you need to add a ajustable pressure box, it will improve your results. People have made some good numbers with BD twins, I dont think its a turbo problem. I think you need to tweak your set up a little. Give it some time you will get it worked out.
Old May 15, 2007 | 06:44 AM
wap's Avatar
wap
Have you ran the track yet?
I know you got a 6spd, but that would be a better judge of performance to me than a dyno. Just a thought.
Old May 15, 2007 | 07:35 AM
Robert P's Avatar
i made 555hp at over 1000 with only some II sticks and a smarty. the clutch, turbo, and cp3 all where stock
