Fluid damper 05
Old May 2, 2009 | 09:30 PM
bishgeo's Avatar
Fluid damper 05
Can I put a fluid damper on an 05 with no modifacations.What damper is best buy for the money.Can I reuse my stock bolts.What to retorque bolts.?
Old May 2, 2009 | 09:56 PM
sid325's Avatar
I run one, no mods needed, don't remember the torque specs.
Old May 3, 2009 | 12:48 AM
cLAYH's Avatar
Whats the advantage of having one?
Old May 3, 2009 | 11:38 AM
PRO-NRA's Avatar
Smooths out the "diesel" vibration inherent to the design. You will not regret it. Fluidampr is the best.
Old May 4, 2009 | 06:06 PM
bishgeo's Avatar
Is fluid damper brand the best or does it matter.
Old May 5, 2009 | 12:37 AM
PRO-NRA's Avatar
IMO it is "THE BEST".
Old May 5, 2009 | 09:08 AM
XLR8R's Avatar
FluiDamPr is the gold standard... you should buy new crank bolts and pin the damper when installing.
Torque is a nominal value + degrees of rotation (i.e. 20ft-lbs + 60*). Torque wrench will click off between 95-135 ft-lbs.
It will help your tranny live longer, too.
Old May 5, 2009 | 10:06 AM
soulezoo's Avatar
DTR 1st Sergeant
Or you can just go the expensive route and have the engine balanced and blueprinted like me....
Fluidampr is a very worthwile addition. It does a much better job than the stocker which was designed with much lower HP and rpms in mind than what we are used to.
Old May 5, 2009 | 10:57 AM
Nate-03 D's Avatar
Was there any increase with power when you put on the FD? They are claiming an extra 10 horse, I don't understand where that would come from.
Dwitt0187
Aug 10, 2008 11:59 PM
dieselcarpenter
Dec 16, 2007 10:04 AM
Jpw
18
Sep 13, 2007 10:10 PM
Mr Bee
Aug 28, 2007 08:02 AM
PourinDiesel
29
Mar 13, 2006 09:04 AM
