Finding the ECM
Finding the ECM
Can someone point me to the ECM on my 04?
Specifically I need to find pin 29 on the C2 block...
Thanks. I looked around a little and discovered there are a bunch of wires and connector blocks in there and the (even remote) possibility of tapping the wrong wire began to concern me.
thanx
thanx
Not sure how you would tap it by reaching in for it.
The ECM is on the drivers side bolted to the engine block. Its rectangluar shaped and some are painted black and some are bare metal.
As far as I know there is only one plug to the ECM on a Ram. You can undo the fasteners on the plug and remove the plug, that should give you the access you need.
I would also disconnect the batteries if you have not already decided to do that.
Exhaust brake or high idler?
As far as I know there is only one plug to the ECM on a Ram. You can undo the fasteners on the plug and remove the plug, that should give you the access you need.I would also disconnect the batteries if you have not already decided to do that.
X-monitor trans temp...
Anyone who has done this, a picture would be valuable.
The X-montor comes with a spiffy little device to tap the right wire if I can ID it. I promise I'll post pics of it all when I finish. Ironically I thought trans temp off the ECM would be a snap... until the instructions arrived. I've got a picture of the right boost bolt. I'm going post-turbo and dropping the elbow to weld a flange should be a snap. I'm just stuck on finding the right dang wire and the friendly folks at BD decided to name the module (ECM) and pin out... put just skip any kind of picture
Well atleast that what my instructions say and they are for the 03-04 X-monitor
Let me know how it goes. I haven't got mine installed yet and I just want to know if you have any troubles with it. I will have to take mine some place to have them install the Pryo Bung for me because I don't have any welding capabilities
Originally posted by SuperGewl
I do believe you are looking for the PCM and NOT the ECM. I have an X-monitor and it requires you to hook up to the PCM which is onthe firewall passenger side. It has 3 plugs. The center one is white and has a violet wire on it that you connect to.
Dan
The instructions have a nice note for 1998-2003 and indicate trans temp on
"PCM (Center Block) Pin 1 - Violet" There's a nice picture and pinout diagram, along with a table with misc other info.
Then the next line says
"2004: ECM (50-pin C2 block) pin 29 - Dark Green w/Orange tracer"
no picture no nothing... I'm pretty sure I'm looking for the ECM, not PCM. I understand why 2003 owners would have installed it differently. I'm still not sure I can find the ECM and pin 29... though with the color code on the wire I'm thinking I'll know when I do find it. I haven't been able to crawl under the truck and look closely at the driver's side of the block yet... though I do kind of remember a couple big rectangular silver boxes down there. I'll go searching on Saturday.
THANKS FOR THE PICS! That pointed me to the right general area... somehow I was expecting that thing to be on the firewall.
We got the X-monitor in fine today. fyi on a 2004 there are two connector blocks and you connect to the rear block of connectors (closest to the firewall). If you pull it off and flip it up a little you can read the pin numbers molded into the connector block. I chose the rear block because it had the right color wire in the right location... so I tapped it. The read out gives temps that match what a tranny ought to run - so I think I got it right.
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
