Fass or stay stock fuel pump
I still have the stock lift-pump on the filter. I put a cheap Carter pump under, on the frame when the truck was new and it's still running strong, 18-19psi and 10-11psi under full load towing. Also I've managed to keep the original injection pump alive for 110K miles. That alone easily justifies the cost of a cheap Carter pump.
I would do a search and take a close look at what AH64ID has said and written about pumps and filters. I can tell you your head is going to hurt. He breaks everything down for you!!! I brought an AD100 and should have brought the Raptor and put a better filter (Baldwin)in the stock filter housing. I brought the AD 100 before reading his posts!
Josh1979
08-02-2011 02:23 PM
RyeThomas
07-09-2011 01:55 PM
mstep3
23
07-27-2010 02:22 PM
jentas
33
03-07-2008 02:45 PM
