FASS install question
Old Feb 1, 2008 | 04:42 PM
Topper's Avatar
Hey guys,
I have a FASS 150 pump and was starting to gather up parts for my fuel system and was wondering if I need to pull the in tank pump or can I pull fuel through it?
Thanks,
Topper
Old Feb 1, 2008 | 05:19 PM
bluechrome's Avatar
To do it correct you need to pull the tank or take the bed off To put a 3/8" or 1/2 draw tube in the tank
Old Feb 1, 2008 | 06:44 PM
Speed Shift's Avatar
The 03s with intank convertions need part# stk-1001. It is the draw tube and bulk head fitting.
Old Feb 2, 2008 | 03:11 AM
Topper's Avatar
Thank guys!
Old Feb 2, 2008 | 08:11 AM
sawboywv1's Avatar
my fass didn't require anything... but its also wasn't the 150gph either
Old Feb 2, 2008 | 08:15 AM
coyle2285's Avatar
my lift pump went out in my 03 and its got one mounted in the tank, and was going to buy the raptor 150, what do i need to install this correctly? Do i need to get the other pump out or what?
Old Feb 2, 2008 | 10:01 PM
pik's Avatar
pik
I have an '03 and got the 95 gph FASS. I just replaced the FASS fuel line on the suction side of the tank and ran it to the cp3. No mods needed to be done to the tank.
Old Feb 2, 2008 | 10:25 PM
The 03s without a intank update dont require a draw tube.
Old Feb 4, 2008 | 11:22 AM
ropnjessi's Avatar
How can you tell if you have an in tank pump?
Old Feb 4, 2008 | 11:25 AM
53 willys's Avatar
look at this thread...if your fuel filter has the black pump on the back like in the 2nd pic then you do NOT have a intank pump....
https://www.dieseltruckresource.com/...d.php?t=190429
Old Feb 4, 2008 | 12:11 PM
ropnjessi's Avatar
Thanks 53 ******, but I never installed my Carter Pump Pusher, so I have no idea if the installer pulled the lift pump from the filter cannister, I was curious to know if there was a way to determine the tank pump location by looking at the top of the tank. I have a feeling the installer did pull the lift pump from the filter cannister though....
Old Feb 4, 2008 | 12:18 PM
53 willys's Avatar
I would assume that your carter pump is mounted along the frame rail some where....you need to climb under your truck and follow the fuel line to see where they go..
Dennis
Dec 4, 2008 08:19 AM
hopak
Jun 5, 2008 03:27 PM
kully560
Mar 18, 2006 06:04 PM
Ramirezh
18
Mar 12, 2006 07:41 PM
Bad Ramer Jamer
Dec 30, 2005 12:37 PM
