FASS 95 Series Filters
Old Jul 5, 2010 | 05:48 PM
dodgediesel's Avatar
Topper sorry for the derail!
Quote:
Originally Posted by dodgediesel
Is there a better filter or WS for the smaller body FASS 95 series than the FASS or Fleetguard filters?? I run the Fleetguard FF 5712 and the FS 19768...
The small filters that run on the FASS 95 size are an odd-ball thread size. For the f/w sep you can get a Luberfiner LFF9594 which has a 90GPH rating, 95% free water and 75% emulsified water sep, so its the closest you can get to stock.
The problem with the FF5712 is its only 10um absolute, and I haven't found a filter in that thread size that is better than 10um with a flow rate that will even come close to working, as it is the FF5712 is only rated at 60GPH.
Guys that run the 95 pump with the 95 filters are really getting screwed by FASS, the instructions call to remove the OE filter, yet the 95 filters are much worse in every aspect than stock. Guys spend a ton of money thinking they are helping their injectors, when really they are probably doing more damage to them than they were stock.
Quote:
Originally Posted by Topper
dodgediesel makes a good point. My pump is a FASS 95 not a 150.Will tha baldwin 1212 work on the 95???
Thanks guys,
Topper
The 1212 wont work on the 95/95 pump (the one that comes with the FS19768) since the thread size is different. I understand FASS made some 95/150 pumps that are the 95 pump with the 150 filters, the 1212 would work on those pumps.
Old Jul 5, 2010 | 05:50 PM
OK, what alternative do us 95 series FASS guys got for a better filter?? Our filters are worse than stock filtration, what gives???? The website says they are a 3 micron filter.....
Old Jul 5, 2010 | 07:34 PM
1985cucv's Avatar
wondering this as well any info?
Old Jul 5, 2010 | 09:31 PM
7500harvester's Avatar
I have not looked at my fass 95 closely lately, but if all that is wrong to put another filter on is the thread size, couldn't the threads be screwed out of the fass base and the appropriate size be screwed back in to match the needs of the filter of your choice. May have to be a custom machine shop thing, but what is the price of peace of mind?
Old Jul 7, 2010 | 02:56 PM
Anyone???
Old Jul 7, 2010 | 03:43 PM
AH64ID's Avatar
I am the one who posted the info on the FASS 95 filters. It is accurate, and came directly from Fleetguard.
There is a better option for the f/w sep for the FASS 95, its a Luberfiner LFF9594. I have not found anything for the final fuel filter that is better than 10um.
Old Jul 7, 2010 | 04:35 PM
U bet AH, thanks for the help bud.
So the 150 series has a better selection of Fleetguard filters with better Micron ratings?
Old Jul 7, 2010 | 04:41 PM
AH64ID's Avatar
The f/w sep uses the common 1-14, so yes you can improve the f/w sep. I haven't found a good fuel filter in the 1.5-16, since most OEM's dont need that much fuel. The HF6604 is a good filter, but its multipass rated so the single pass specs are unknown.
Old Jul 8, 2010 | 12:02 PM
Topper's Avatar
When I bought the Fass setup I was told that the 2003 filter was a 3 micro. Is this not the case?
Topper
Old Jul 8, 2010 | 02:11 PM
AH64ID's Avatar
Topper
It is absolute at 3um, and 95% at 1um. But those are multi-pass specs since the filter is a hydraulic filter, not a fuel filter. I am not sure how many passes the SAE specs allow to determine the rating, but its more than 1. This is fine in a closed loop hydraulic system, but fuel specs are single-pass for a reason. (Even thou all the fuel in your tank goes thru the filter at least every hour, despite how much you are burning). So its unknown what the single-pass ratings are. I have seen the absolute rating rise 2-4um from multi-pass to single pass, I have also seen the efficiency only change by 1%, but a 2-4um rise is more common.
Old Jul 8, 2010 | 02:49 PM
Topper's Avatar
Thanks for the info! I may hook back into the stock filter and put a 3mic filter in that. Any body doing that?
Topper
Old Jul 8, 2010 | 03:31 PM
AH64ID's Avatar
Lots of folks are running thru the OE canister, but the best filter you can get for it is the Baldwin PF7977, its 5um absolute.
Old Jul 8, 2010 | 07:07 PM
Topper's Avatar
Rip was telling me he sells a 3 micron filter for the oe canister. Ever hear of it?
Topper
Old Jul 8, 2010 | 07:10 PM
AH64ID's Avatar
Topper
AFE makes one that is marketed at 3um, but thats nominal. Its actually 7um absolute, and not a f/w sep.
Old Jul 8, 2010 | 08:49 PM
1985cucv's Avatar
yeah baldwin here pf7977 and 2 micron after that. topper that might be why you have been having issues?
