FASS 95 Series Filters
Topper sorry for the derail!
Quote: Originally Posted by dodgediesel Is there a better filter or WS for the smaller body FASS 95 series than the FASS or Fleetguard filters?? I run the Fleetguard FF 5712 and the FS 19768... The small filters that run on the FASS 95 size are an odd-ball thread size. For the f/w sep you can get a Luberfiner LFF9594 which has a 90GPH rating, 95% free water and 75% emulsified water sep, so its the closest you can get to stock. The problem with the FF5712 is its only 10um absolute, and I haven't found a filter in that thread size that is better than 10um with a flow rate that will even come close to working, as it is the FF5712 is only rated at 60GPH. Guys that run the 95 pump with the 95 filters are really getting screwed by FASS, the instructions call to remove the OE filter, yet the 95 filters are much worse in every aspect than stock. Guys spend a ton of money thinking they are helping their injectors, when really they are probably doing more damage to them than they were stock. Quote: Originally Posted by Topper dodgediesel makes a good point. My pump is a FASS 95 not a 150.Will tha baldwin 1212 work on the 95??? Thanks guys, Topper The 1212 wont work on the 95/95 pump (the one that comes with the FS19768) since the thread size is different. I understand FASS made some 95/150 pumps that are the 95 pump with the 150 filters, the 1212 would work on those pumps. |
OK, what alternative do us 95 series FASS guys got for a better filter?? Our filters are worse than stock filtration, what gives???? The website says they are a 3 micron filter.....
wondering this as well any info?
I have not looked at my fass 95 closely lately, but if all that is wrong to put another filter on is the thread size, couldn't the threads be screwed out of the fass base and the appropriate size be screwed back in to match the needs of the filter of your choice. May have to be a custom machine shop thing, but what is the price of peace of mind?
Anyone???:(
I am the one who posted the info on the FASS 95 filters. It is accurate, and came directly from Fleetguard.
There is a better option for the f/w sep for the FASS 95, its a Luberfiner LFF9594. I have not found anything for the final fuel filter that is better than 10um. |
Originally Posted by AH64ID
(Post 2798209)
There is a better option for the f/w sep for the FASS 95, its a Luberfiner LFF9594. I have not found anything for the final fuel filter that is better than 10um. So the 150 series has a better selection of Fleetguard filters with better Micron ratings? |
(Post 2798234)
U bet AH, thanks for the help bud.:cool:
When I bought the Fass setup I was told that the 2003 filter was a 3 micro. Is this not the case?
Topper |
(Post 2798708)
Topper |
Thanks for the info! I may hook back into the stock filter and put a 3mic filter in that. Any body doing that?
Topper |
Lots of folks are running thru the OE canister, but the best filter you can get for it is the Baldwin PF7977, its 5um absolute.
Rip was telling me he sells a 3 micron filter for the oe canister. Ever hear of it?
Topper |
(Post 2798974)
Topper |
yeah baldwin here pf7977 and 2 micron after that. topper that might be why you have been having issues?
