Fass
Lift pump- do I need it now?
Truck runs great but has a surge feeling when running 70-75mph and ease off the throttle, if throttle is completely let off, it does not do this. Lift pump issue or injector pump? Factory replaced lift pump with an updated one about 1 1/2 yrs ago. Truck blew a fuel line on injector 5 and after that was fixed is when i noticed this surge. Thinkin it is pump issues but not sure. If I do a replacement, what all should I replace when doing the fass or raptor swap?
I have not had that issue but I replaced my factory lift pump with the airdog. The install was not too bad and the mistakes I made could have been avoided by reading Willys43's post before install instead of after.
Either way, if you do anything other than commuter driving, a better lift pump is a must. Mileage increases and fuel delivery is much more reliable.
BCarmicle
13
Nov 7, 2005 04:20 PM
Buckshotmckee
May 23, 2005 12:08 AM
Flatty
Apr 25, 2005 12:49 PM
