Ez Surge- What's Wrong?
I have a surge with the EZ box on #4 and less as I go down on levels. It is mostly at idle and lower RPM's and seems to minimize as the engine gets warmer. Is this normal? If not, what's wrong? Thanks for your help as always.
Originally posted by el jefe
Are you talking about a surge at idle or when you let off the throttle and the truck continues to "surge" forward?
I agree w/ Dave D now that you actually stated the symptoms. Are you sure it isn't just the truck and not the EZ. When it is cold out mine has a slight surge at idle which is normal. It has something to do with the fuel injection. I suggest taking the box off for a couple of days and see if the truck still has the symptoms...The problems I had w/ my EZ only happened when the truck was warmed up........
Jonesey
Mar 22, 2003 09:32 PM
