ez edge trouble
Old Sep 24, 2004 | 11:34 PM
dsl-nut's Avatar
Muted User
ez edge trouble
I installed a ez in my dads 04 305 and about a 100 miles later the check engine lite came on and the truck jerked around anybody have an idia what the truoble mite be?
Old Sep 25, 2004 | 01:49 AM
SuperGewl's Avatar
It's the EDGE EZ
Old Sep 25, 2004 | 01:57 AM
mudslinger's Avatar
I can't personally say, but I would bet the guys in the know are going to want some more details...
Old Sep 25, 2004 | 05:55 AM
localnet's Avatar
Check your connections. Something is probably loose or reversed.
Mike
Old Sep 25, 2004 | 06:42 AM
Dodgezilla's Avatar
I agree with localnet. Make sure the connections are all tight.. Did you buy a used EZ? Possibly someone sold you a bad unit....
Old Sep 25, 2004 | 03:24 PM
dsl-nut's Avatar
Muted User
its a new unit and the conections are good
Old Sep 25, 2004 | 07:12 PM
HO Cummins's Avatar
Sounds like a bad box. It does happen once ina while. Give egde a call
Old Sep 25, 2004 | 07:13 PM
Dodgezilla's Avatar
Call Edge Products on Monday. They have pretty good customer service...
Did you try removing the unit completely and checking that all the pins inside the connectors are straight? Maybe you bent one putting them together.
Did you inspect all the wiring to make sure something didn't melt. If it worked fine for a short period and then started having the problems, that may be the cause...
Supergewl!! You're a genious!!
Old Sep 25, 2004 | 08:07 PM
gsdog1's Avatar
You will need to pull the codes, if you haven't already. Edge will need them in order to diagnose what is going on.
And the rest of us are interested as well!
Seriously, Edge is a stand-up outfit, they should be able to get everything right for you.
Matt
Old Sep 25, 2004 | 09:20 PM
gsbrockman's Avatar
May want to make sure they sent the proper box....did they send one for the 305/555 or the 325/600 ?
Greg
Old Sep 26, 2004 | 10:40 PM
dsl-nut's Avatar
Muted User
Iv got 200 miles on now and no more trouble who knows i am going to check the codes tho
Old Sep 27, 2004 | 04:20 AM
Dodgezilla's Avatar
At least it's easy to pull off if you need to.....
Old Sep 27, 2004 | 10:34 PM
mattymac's Avatar
wiggle the wires going into the fuel pressure sensor while the motor is idling. they had a bad batch of grommets that over time would get loose and have a hit/miss connection.
Old Sep 27, 2004 | 10:48 PM
ttreibel's Avatar
I used some dielectric grease when I put the connections back together just to be safe.
Old Sep 28, 2004 | 06:19 PM
Rolngthun's Avatar
Greg
I don't think they have a box for the 325 yet.
