External Wastegate Questions
Old Jul 7, 2009 | 12:18 AM
ScienceOfSpeed's Avatar
i am going with a Turbonetics turbo,and a stainless manifold, which wastegate holds up to the extreme temps? also what are the thoughts on mounting the wastegate on the downpipe? i know the wastegate is usually mounted on the exhaust manifold/header. the reason i ask is i had a 93 GMC Typhoon, i was running a custom turbo with a 3.5 inch downpipe and my wastegate had the ports attached to the downpipe. thanx
Old Jul 7, 2009 | 12:29 AM
1slo_MM's Avatar
What do you mean by "mounting the wastegate on the downpipe?" It has to go pre-turbo.. The dump tube can be rerouted into the downpipe though. .02
Old Jul 7, 2009 | 10:07 AM
soulezoo's Avatar
DTR 1st Sergeant
^^^ what he said above...
There are two worth playing with: the Tial which will tap into your exhaust manifold... it is cheaper, reliable and been around a long time.
The other is from Engineered Diesel. It is expensive and big, and sometimes problematic to fit depending on the situation, but more effective and a really top notch unit.
Old Jul 7, 2009 | 06:58 PM
Nsomniac05's Avatar
I have seen ED's wastegate setup that mounts between the manifold and the secondary. Very good looking unit. Did its job as advertised.
1ST GEN.
21
Apr 14, 2005 10:01 PM
RowJ
Mar 1, 2005 04:50 PM
AK RAM
24
Jan 20, 2005 08:50 PM
KatDiesel
Mar 11, 2004 07:31 AM
