exhaust brake
Old Mar 5, 2013 | 06:47 PM
03hayhauler's Avatar
Question exhaust brake
okay i have decided to put an exhaust brake on my 03.it has 5in exhaust on it and i plan on going with a different turbo later on. will turbo mount exhaust brake fit on a aftermarket turbo or should i go with a 5in inline from pacbrake?? is an exhaust brake worth spending money on??thanks in advance
Old Mar 5, 2013 | 08:18 PM
C Schomer's Avatar
I went with inline so the turbo situation would never matter and it works great. The guy I got mine from had a 5" and I think he said it didn't build quite as much pressure as a 4" but it still worked good. I wouldn't spend the money if I didn't tow. Craig
Old Mar 5, 2013 | 10:56 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I run 4" dia stainless from the turbo back to the stacks and I made my own exhaust brake. I suggest you use the inline version... easier to work on, install and if you ever need to take it out, a short pup will be easy to install there.
Old Mar 6, 2013 | 08:03 AM
Thanks guys we tow heavy with this truck quite abit.it has a 4in down pipe on it can a inline be installed there?
Old Mar 6, 2013 | 08:35 AM
Danavilla's Avatar
I've never had a "in-line" brake so can't advise there but you won't regret having an e-brake if you haul heavy. They're definitely worth the investment.
Old Mar 6, 2013 | 10:09 AM
I have the manual tranny does it come on when i let of the pedal or can I get a switch to turn it on and off when im driving maybe like a push pull switch on the shifter
Old Mar 6, 2013 | 08:03 PM
C Schomer's Avatar
I put mine at the bottom end of the DP, just ahead of the trans x-member. It will have controls and the initiating circuit that goes thru 2 of the ecm ports to keep it from coming on if there is any throttle signal or the cruise turned on. I got a $6 push/pull switch and put it on the shifter. No throttle sw. is necessary like with an engine brake. Craig
Old Mar 7, 2013 | 07:35 PM
should i get the whole package from pacbrake or should i just get the brake and buy a airtank an compressor separate?im going to run airbags and maybe airhorns to
Old Mar 7, 2013 | 07:58 PM
C Schomer's Avatar
I pieced mine together cuz I already had some of the stuff. Chuck - healdworks.com sold me the inline brake, 4" pipe adaptors and the control kit. I did the rest and saved ~$200 and got a better system. Craig
Old Mar 7, 2013 | 08:31 PM
I thought about getting one of those vaiar 2 gal tank an compressor kit it around 200 dollars is that a good set up I think the pump is like a 30% cycle or something like that.
Old Mar 8, 2013 | 08:28 PM
C Schomer's Avatar
This is the compressor I got 3 yrs ago and it's way more than I need but I do need more tank capacity when I blow up the bags. 30% should be enough unless you air up tires. Craig http://www.amazon.com/VIAIR-Series-C.../dp/B007XANJ3A
Old Mar 9, 2013 | 05:33 PM
carl48's Avatar
several things, i like the bd brake better than the pac because of where the compressor is mounted. we had to move our pac compressors due to high failure rate. i have in line and exhaust elbow. our 03 has a he351 off of a 05 and elbow the truck in my sig has a hitek 62-65-13 with elbow. mount the switch on the shifter. i forgot to order one and used a toggle switch for temp, i liked it so much i left it on. use it often and get a maxbrake controller. one trip and you will kick yourself for not doing it sooner. the jake is junk and does not work very well. the first switch is from the old jake, i just reused it on the bd.
Old Mar 11, 2013 | 05:48 PM
Okay I have my truck in the shop doing a ujoint and I looked at the exhaust it doesn't turn into 5in till it gets to the transfer case is that to far back for the brake.or can i get adapters to put it in the four inch pipe ????
Old Mar 17, 2013 | 03:53 PM
C Schomer's Avatar
I just took some pictures of mine. I can email them if you send me your address. Craig
Old Mar 17, 2013 | 09:45 PM
hot_runner58's Avatar
just my 2cents, but I recently insalled the pac. 2 months ago. Love it, especially in town echoing off the buildings. But, besides that, the only thing about putting it farther down the exhaust pipe, is that it has that much more pipe to back pressure before it will work like you want. How much affect it has on how it performs I don't know but the closer to the turbo the better.
rcs7
Sep 30, 2009 12:05 PM
Mopar440_6
Feb 11, 2007 10:50 PM
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
