Evil Twins setup - help
Ok, let me preceed my question by saying I suck at being a mechanic. Also I figure the answer is pretty simple but my feeble mind cant process what I need to do...Now that you know I am pretty much worthless
here is my question : How do I plumb the top pump up with the bottom? I have done away with my stock fuel filter b/c I am using the Air dog and the 1/2 inch line kit to come into the bottom pump.
Just trying to figure out when you locate the return port on bottom cp3 you are supposed to plumb it up with the return port on the fuel filter housing. But what if I did away with the stock filter? Do I still plumb it in and use the return line of the stock filter anyway?
Then you are supposed to supply the low pressure fuel inlet on the top cp3. How do I do this? Do I make some sort of "T" connection off the Air Dog fuel supply line? I got a few more questions but I will wait on those.
here is my question : How do I plumb the top pump up with the bottom? I have done away with my stock fuel filter b/c I am using the Air dog and the 1/2 inch line kit to come into the bottom pump. Just trying to figure out when you locate the return port on bottom cp3 you are supposed to plumb it up with the return port on the fuel filter housing. But what if I did away with the stock filter? Do I still plumb it in and use the return line of the stock filter anyway?
T your returns together and tie them into the tank return then t the two feeds together going to the pump from the air dog. You may also have to t in the injector return as well but I dont know what you did with that when you took you filter housing out.
Glacier Diesel has a write-up on installing their twin cp3 big line kit. It has some good pics and descriptions for this portion of the install.
http://www.glacierdieselpower.com/im...it-Install.pdf
I have my Evil Twins setup sitting at my house right now, waiting for me to install as soon as I get back from vacation. If you get around to it, I'd like to hear your thoughts/writeup on the install. Good luck,
Jared
Jared
MartinRdCustomz
Jun 7, 2011 08:39 AM
genros
22
Feb 23, 2008 08:23 PM
