Evil Twin Dual CP3 Pump Kits Release Date
Old Apr 6, 2008 | 10:37 AM
  #76
Bswope's Avatar
Travis im not sure anymore! My thoughts are to try twin pumps with some flux 3.3's and a single 64(maybe a 66) sized charger that way when i have the money i can put a S480 under the 64 and jump up to some bigger sticks!
Studs are my next step though!
Old Apr 6, 2008 | 10:41 AM
  #77
Bswope's Avatar
thanks for the info guys....it seems like the cummins pumps is cheaper then the D-max pump...I did find a 07 dmax pump with only 6000 miles on it but they want $450...if I can get a Cummins Cp3 for $250 and I wont notice any performance draw backs then I would just get the cummins Pump..
Thoughts???????
Mark where did u find that 07 Dmax pump???????
Old Apr 6, 2008 | 10:46 AM
  #78
53 willys's Avatar
haha if I tell you then you will go buy it and I am still not sure witch pump I want/need
but I will send you a link to it soon as llyod chimes in with his thoughts
seems to me that you could never drain the rail with a dual CP3 set-up so the cheaper cummins pump is probably what I will do??? I just am still undecided
Old Apr 6, 2008 | 10:52 AM
  #79
Bswope's Avatar
Yeah either way it dosent really matter, im just gonna end up with a Dmax pump cause my buddy want a LBZ or LLY pump for his truck!
Yeah send me that link when Lloyd lets ya know.
If i wasnt gonna end up with a Dmax pump i would go the Cummins pump just cause its the Cummins pump.
Old Apr 6, 2008 | 10:55 AM
  #80
53 willys's Avatar
I know I know it's probably 6's either way.......and $250 for a pump is a pretty great deal...I will send you link soon as I hear something
Old Apr 6, 2008 | 01:38 PM
  #81
lmills's Avatar
My personal thought? I have done no side by side comparison to see which flows more. I never gave it much thought since I figured a stock cummins pump will usually support around 550-600 HP. That means even if the cummins pump did flow less and was used in a dual pump configuration you would still have enough fuel for 1100-1200 HP. If you decided to go with a duramax pump, and if it did flow more, you would just be a little further ahead, but most would never use that much fuel.
Old Apr 6, 2008 | 01:43 PM
  #82
53 willys's Avatar
Thanks Lloyd I guess I was putting to much thought into it Thanks for the info
Old Apr 6, 2008 | 02:40 PM
  #83
Billm2004's Avatar
I just bought a pump and now i need one of these kits! do you have any ready to go, or do i need to put a deposit to get one made for me?
Old Apr 6, 2008 | 07:25 PM
  #84
53 willys's Avatar
X2 Lloyd..I know we talked about it through PM but I never asked if the evil twin kit was ready to go right now???
Thanks Mark
Old Apr 6, 2008 | 10:14 PM
  #85
94ttss's Avatar
Here are the latest pis with the Cummins pump.
Old Apr 7, 2008 | 03:16 AM
  #86
Billm2004's Avatar
how difficult is the install, im not a mechanic but i have done every mod on my truck myself so i was wondering if i could manage this. what has to be removed to do the install?
Old Apr 7, 2008 | 06:25 AM
  #87
heykw's Avatar
wear do you get a cp3 for $250.00 I need one
Old Apr 7, 2008 | 08:50 AM
  #88
53 willys's Avatar
Am I going to need a regulator like the one in this bottom pic??? I think that is just for the your regular lift fuel pump right??
Old Apr 7, 2008 | 09:19 AM
  #89
tristan21's Avatar
is that just a catch can I see in the pics
Old Apr 7, 2008 | 10:34 AM
  #90
cquestad's Avatar
If you use a Dodge CP3...you don't have to be so concerned about lift pump pressure. GM's don't like more than 15 psi at the inlet...
