Evil Twin Dual CP3 Pump Kits Release Date
Old Apr 7, 2008 | 10:38 AM
  #91
53 willys's Avatar
Originally Posted by cquestad
If you use a Dodge CP3...you don't have to be so concerned about lift pump pressure. GM's don't like more than 15 psi at the inlet...
that is actually really good info!!! I noticed "Triton" had a thread about his dmax pump making noise with high lift pump psi.....I am going to get the cummins pump for mine....especially since it is a cheap pump to buy used.
Old Apr 7, 2008 | 12:40 PM
  #92
lmills's Avatar
Kai and I have both ran 25 psi at the inlet of our dmax pumps. We have never had a problem with high rail pressures at idle.
Old Apr 7, 2008 | 12:43 PM
  #93
OldSmokey's Avatar
Lloyd any word if they will work with a jacobs exhaust brake with a belt driven vac pump?
Old Apr 7, 2008 | 03:15 PM
  #94
Billm2004's Avatar
hey lloyd i sent ya a reply about the kit.
Old Apr 7, 2008 | 03:19 PM
  #95
tritont's Avatar
I don't have that problem either. It's when the peddle is depressed that to much LP psi seems to be a problem.
Why do you think you've not had the FCA buzz problem running the psi you do ?... or have you ? are you using Cummins FCA's
Old Apr 7, 2008 | 08:01 PM
  #96
53 willys's Avatar
well I picked up a 06 cummins CP3 with about 10k on it today so I am ready!!Lloyd did you get my PM??
Old Jul 13, 2008 | 12:43 PM
  #97
XLR8R's Avatar
Using the Evil Twins (stage II CP3 & OEM CTD CP3) and a Raptor 150, is there a benefit to using 1/2" low-pressure fuel line? ..... and does that then make the drawstraw the chokepoint?
This would be at the 1K HP level.
Old Jul 13, 2008 | 02:07 PM
  #98
53 willys's Avatar
I think 1/2" line can only help...volume is always nice..not just PSI.
if your using the stock pick up then yes that would be the choke point...but if you run a 1/2" drawstraw then you would have 1/2" line the whole way to the CP3's...no choke point......
Old Jul 13, 2008 | 03:22 PM
  #99
Billy Ram's Avatar
Very nice looking kit and you can't beat the price. I'm going to be on the look out for a good cp3. Duel cp3s are the way to go. The tnt-r56 has no problem draining my stage I.
Old Jul 13, 2008 | 08:23 PM
  #100
94ttss's Avatar
I agree the big line can only help. I run a 5/8 draw straw and -10 to were it splits -6 to each cp3.
Old Jul 14, 2008 | 09:44 AM
  #101
XLR8R's Avatar
Did you & Lloyd ever see any solid numbers, either in K's of psi RP at max fueling (or dyno HP) between -6 line & either -8 or -10?
Old Jul 14, 2008 | 12:13 PM
  #102
Billy Ram's Avatar
Can a cp3 off a 03 be used with this kit on a 04.5?
Old Jul 14, 2008 | 06:17 PM
  #103
94ttss's Avatar
The only thing I've found is that with a -06 line feeding the two cp3's my fuel pressure would fall to zero on the top end of a 0-120mph run usually right at around 2700 rpm. With the -10 line it has not been an issue. I am currently running a Bosch 044 pump, output is about 20% more than a walbro.
Any year cp3 can be used with the kit.
Old Jul 18, 2008 | 09:14 AM
  #104
lmills's Avatar
just checked PM's, I have none from you.
Old Jul 18, 2008 | 09:17 AM
  #105
lmills's Avatar
As for the 1/2" line, I ran it cause I wanted to be sure to have the volume of fuel. Some of the other kits have used considerably smaller line and never had a problem with making power. So, I do not personally think it it makes a huge difference. I just did it to keep everything uniform since the airdog system comes with 1/2"
