EMS hub conversion with factory hub caps (pics)
Old Dec 17, 2007 | 07:39 PM
abc4yew's Avatar
Anyone have some pix of a set of properly offset larger rims with 37's and the normal ems or dynatrac kit...I'd like to see the stubby kit on this set up....if it isn't within the tire rim profile or very close I'm waiting....I'd like to see a specially made complete hub with its own lockers...it ain't rocket science. KS.
Old Dec 19, 2007 | 12:34 AM
duck8511's Avatar
free spin & fuel mileage
Everybody is posting about the distance sticking out past the wheel on the freespin. yet nobody has asked the main question! what has the 1700-2300 bucks get you for your dollars spent! what is the gain in fuel mileage? @ 3.55 a gallon here in california. someone show us some results! or was it just to say you spent another 2 grand on some thing that was saposed to be a life saver on fuel costs that didnt put out!
Old Dec 19, 2007 | 07:18 AM
DiEseLjunKy's Avatar
Mine was under $2000. Got me the abilty to add oversized tires without putting too much stress on the stock bearings that really aren't designed for them. The ability to inspect my bearings or in the chance that they go bad replace them and the races for about $50. Picked up 2mpg. Is that enough?
Old Dec 19, 2007 | 09:05 AM
DODGER BOMBER's Avatar
i gained about 1.5-2 mpg adding this and thats with my mods. There HAPPY
Old Dec 23, 2007 | 07:16 PM
rootercycles's Avatar
They do stick out a bit, but unless you are doing rock climbing or trail riding, they are fine. Thanks again DiEseLjunKy for doing my caps! I think that the combination of the powdercoated rims and old caps looks great. Of course my OEM tires are small, but new ones are way too expensive just to throw these out. Even though my EMS kit turned out great, there was way too much extra work that you wouldn't have to do with the Dynatrac kit. I am not sure what else can be bought off of the shelf with the kit other than the stub shafts and the inner and outer hubs. Hopefully, I won't need anything for a long time...
Old Dec 23, 2007 | 07:35 PM
jmccart's Avatar
If you have a lift it is the handy step into the engine compartment.
Old Dec 23, 2007 | 09:47 PM
Rednecktastic's Avatar
I'm just going to buy a used knucked dana60 and get it ready for my truck.
Two birds, one stone.
Old Dec 24, 2007 | 07:17 AM
Asher's Avatar
I had a newer (at least 2006 model) ford SD pull up beside me at a stop light the other day that had factory locking hubs, and they where flush with the hub caps.... Don't these trucks run the same front axles that we do??? If so has anyone considered using the knuckles and hubs from one of those??? I like the locking hub idea, but having "custom made" parts can be a real bear when you get caught out in the middle of no where broke down...
Old Dec 24, 2007 | 07:37 AM
realsquash's Avatar
What extra work did you need to do?
Andy
Old Dec 24, 2007 | 08:00 AM
Hintz's Avatar
ford's have Dana 60s, dodge is an AAM 9.25, the swap wouldnt work
Old Dec 24, 2007 | 01:01 PM
Bearings, races, and seals on dynatracs and ems are standard off the shelf parts that can be bought for cheap at any autozone etc..
Old Dec 24, 2007 | 02:14 PM
Highway 4x4's Avatar
The reason the hubs have to stick out so much, IMO, is due to the wheel off set. that is the wheel is so shallow on the outside, done to center the bearings in the center of the wheel. The unit bearings, inner and outer are very close to each other and wheel offset to the outside would kill them soon. That's why adding front axel load, plow, and turning the stearing wheel alot, plowing, kills the bearings. These trucks are made to go down the highway, not much else, LOL. Oh, and just foreget about deep water. With the Hub kits the bearings are farther apart, giving the wheels, or bearing unit, more strength for wide tires and all. But the bearings are on the outside of the wheel so they stick out, and you have to add a locking hub to it. If I am wrong just tell me.
Old Dec 24, 2007 | 03:40 PM
The bearings evenly spaced apart about 3" or 4" in the hub kits like they ought to be. The warn lockers on the end and the space needed for those is what makes it stick out so far. On the factory unit they're spaced apart about a 1/2" and make for a nice stressfull "pivot" point for the big tires, plows, bumpers, etc I would imagine the with how they're so flush the factory Ford lockers bearings don't have much better spacing than stock Dodge..
Old Dec 24, 2007 | 07:05 PM
On the Dynatrac suite it looks like the stub hubs will fit the dodge conversion kit. Should be about the same price, I did say should, didn't I?
Old Dec 24, 2007 | 07:41 PM
Might cost you another leg or even a small child I dunno
