EGT Tap size, and questions with install. Help Appreciated
Old Jan 7, 2009 | 06:48 PM
WhozNxtLS1's Avatar
Hey guys. This weekend I think I'm going to install my EGT gauge which I've been putting off forever due to me being afraid. I think I'm going to stop being such a panzy and just go for it.
Anyways, I bought a Cobalt EGT gauge and have a couple questions.
First and foremost what size is the tap for the gauge to fit in. I believe I lost the instuctions that came with the kit.
Also, what size drill bit should I use to drill the hole itself.
Also, there is a red (assuming power) black ( assuming ground) and white (clueless on what this one is) that plug into a male female connector to the back of the gauge itself. Only question is does this sound right with what color the wires are, and what is the white one.
Thanks again for any advise. Thanks
Chris
Old Jan 7, 2009 | 07:18 PM
jlibert's Avatar
IIRC it's a 5/16 or 11/32 bit, and 1/8 npt tap -- normally.
Old Jan 7, 2009 | 07:39 PM
megacabdad's Avatar
This page may help 'ya...
http://www.dieselmanor.com/dm_products/TAP1418.asp
Check out the install sheets, also!
Old Jan 7, 2009 | 08:55 PM
nwflyoda's Avatar
i just did mine last weekend. yup, its a 11/32 bit w/ the 1/8x27 npt tap. just make sure you drill the manifold in the right spot i didn't realize there was a divider in the manifold which cause my bit to break off into the turbo. so i got to spend the rest of the afternoon pulling the manifold and turbo assembly out to disassemble the turbo and make sure i got all the pieces out.
Old Jan 7, 2009 | 09:01 PM
tslewisz's Avatar
Dang...I didn't know about a divider. Glad I got lucky...sorry you didn't, too.
Old Jan 7, 2009 | 09:12 PM
nwflyoda's Avatar
yeah it sucks, but it happens. at least i'll try and keep people from making the same mistake i did. i've welded the hole so i don't have an exhaust leak. the best place to drill is to drill on the left side of the manifold going to the turbo flange (as your looking at the motor from the passenger wheel well) if that makes sense.
Old Jan 8, 2009 | 02:23 PM
WhozNxtLS1's Avatar
Hey thanks for the help guys. I will let you know how it goes. Still a little afraid lol
Old Jan 8, 2009 | 03:32 PM
TX_Diesel's Avatar
I believe the white wire will be for the lighting of the gauge. You can connect this straight to power (so it's on all the time) or you can hook it up to your dash lights so it's only on when your dash lights are on.
Since i dont' know exactly what guage you have, double check to make sure.
Old Jan 8, 2009 | 07:50 PM
WhozNxtLS1's Avatar
I checked the install instructions online, it shows 12v to dash for the white wire. I would certainly imagine to a dimmer.
Old Jan 8, 2009 | 07:54 PM
Blake Clark's Avatar
Just a bit of advice to go extra careful with the tap.
When I did mine drilling went fine, and the tap was going butter smooth, then with no warning, stress or effort, the tap broke off clean in the manifold.
And trust me, the manifold position on a 6.7 is well... less than friendly.
Told me a few hours to get it out, thought I was gonna have to yank the whole manifold for a while.
Just a friendly bit o my two pennies....
Old Jan 8, 2009 | 08:08 PM
smokin 5.9's Avatar
Also when you drill / tap put grease on the bit and the tap to catch the metal. If some fall down don't worry it will blow right out the exhaust. good luck and don't be scared
Old Aug 4, 2009 | 03:54 PM
Wilbur01's Avatar
I started with a smaller drill bit and worked my way up. I used a shop vac at the drill tip to pick up any shavings. When using the tap, use grease and make a half of turn forward and the 1/2 turn back. This keep the cutting edge of the tap clean and will help prevent them from breaking which is not fun.
Old Aug 4, 2009 | 04:08 PM
cincydiesel's Avatar
Also, might want to tap towards the back of the manifold wall were cylinders 5 and 6 exit.. Those seem to run the hottest.
Old Aug 4, 2009 | 04:37 PM
Ace's Avatar
Ace
I used a dremel tool to make a spot for getting it started in at an angle like this. Angle it into the rear channel, avoiding the divider:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_24.JPG
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
06Cummins
May 23, 2006 04:20 PM
Hoss
Apr 11, 2006 11:37 PM
Dodgezilla
Aug 22, 2004 06:12 AM
