egt gauge wiring question
Old Apr 14, 2007 | 10:59 AM
koogala's Avatar
On the hot wire running to power the gauge, inst. say run hot wire to
switched source. Is there a reason I couldn't run it straight to fusebox or battery? Much easier than tearing into packed up factory harnesses under
dash. Maybe cause it would drain battery? Seems like it wouldn't draw anything unless truck was running...
Old Apr 14, 2007 | 11:09 AM
RedRacer44's Avatar
We pulled the dash cover off and hooked the hot-wire up to my cig. lighter since I dont smoke and dont let anyone smoke in my truck...that was the easiest for us. Then just grounded it out...works great.
Old Apr 14, 2007 | 11:18 AM
koogala's Avatar
Yeah, I thought about that & think that I'll do that,too. Anybody know why
cig. lighter hot wire would be bad idea? I wasn't gonna use it cause it wasn't a swithched source. I guess only question I have is would it drain batt? I can't
imagine that since the alarm light blinks on the dash all the time when truck is locked. Lighter is right there & easy to access...
Old Apr 14, 2007 | 11:23 AM
RedRacer44's Avatar
I've had mine hooked up this way for....wow, several months. Never an issue...truck has sit for 3 or 4 days without being driven with no battery issues.
Old Apr 14, 2007 | 11:33 AM
RamWheelsBy4's Avatar
The lighter is switched and only on when the key is in the on position. I use it for some of my gauges.
Old Apr 14, 2007 | 12:38 PM
WUnderwood's Avatar
the install instructions from Geno's say to tap the hot wire for the cig lighter, many have it done this way, including me, and no problems so far
hope this helps
Old Apr 14, 2007 | 12:45 PM
Mexstan's Avatar
I have used the cig wire as well. Checked it before using and it is only hot when the ignition switch is on.
Old Apr 14, 2007 | 12:48 PM
Goober's Avatar
Is the cig lighter always a hot wire or does it shut off when the truck goes off.
Old Apr 14, 2007 | 12:52 PM
WUnderwood's Avatar
it shuts power off when the truck is off
Old Apr 14, 2007 | 01:59 PM
koogala's Avatar
Ok, etg gauge up and running. I hooked it to a unused 4 wire plug that was just attached to a dummy plastic receptacle on the backside of the plastic
radio/ac/vent dash cover. It is to the right of and below the radio, kind of in the area where the plastic bag hanger/hook is. It has a switched hotwire to it. WHAT is this.. ?
Old Apr 14, 2007 | 02:00 PM
jrussell's Avatar
On my '06 the passenger side cig lighter is hot all the time. Only the driver side is switched. Don't use the wrong one!
Old Apr 14, 2007 | 02:03 PM
Mexstan's Avatar
Going to take a guess that it is the on/off switch for the passenger air bag. Not all models have the switch installed but it appears to be pre-wired for the switch.
91r/t
Feb 22, 2012 01:16 PM
wild4stangs
Apr 23, 2007 06:06 PM
jmccart
Mar 18, 2007 10:03 PM
Timmay2
Jun 25, 2006 12:38 PM
charcoal600
Apr 30, 2005 02:34 PM
