Edge Juice w/ Attitude
Old Jun 25, 2012 | 06:52 PM
mdg2434's Avatar
Anybody have this chip? Do you like it? Let me know all about it!
Thanks!
Old Jun 25, 2012 | 07:26 PM
madhat's Avatar
Administrator/Jarhead
I have in the past. What year truck are you talking about?
It is a good starter box. Most of the gauges, fairly cheap, good power for a stock truck. Air box mods/CAI and a fuel pump are all your need to have a strong stocker.
It will eat a clutch/tranny up in a few months if you drive hard, longer if you take it easy. If you keep it on 3 and don't drive like a retard, you can see 6+ months for an auto that is in good shape to begin with.
They do have good customer service for the most part.
Easy install, except for the EGT probe. If you are mildly mechanically inclined, it's not hard. (drill and tap)
Down sides: Not good when you start to grow, i.e. injectors, turbo.
It adds fuel and timing hard to make the power.
I never believed the EGT... my analog gauges were so much different than the edge display.
I have had one and installed a few on third gen and second gen trucks. Ask if you have questions.
HTH.
Old Jun 26, 2012 | 08:29 AM
hot_runner58's Avatar
I have had 3 on my 04.5, the CS is def. the best of them. As mentioned above, it has most of the guages on it, which is nice. The ONLY thing I don't like about it on mine is that when I get pulling a load, my EGT's are high, shoot over 1200 when I have to get on it. My welding rig weights just under 12,000lbs, and even just running it around when I jump on the gas the EGT's shoot over 1200. But, other than that it is a nice chip. I am trying to sell it to get a smarty. Even though you have to buy a gauge cluster, they claim good low egt's, plus they have lots of tuning options. But, if you aren't gonna do a ton of mods and just want a good chip, I would recommend it. I have had it for 6 years, well versions before the cs also.
Old Jun 26, 2012 | 08:37 AM
I should add though, the 5 power levels and on the fly adjustment is nice. You can also adjust each level for how much you want it to smoke. Has good power and upped my mpg about 1.
Old Jun 26, 2012 | 02:57 PM
Falcon1's Avatar
I like mine, tow and drive on level 3, but I also have a 3250 SB in it also.
Old Jun 26, 2012 | 03:02 PM
klx650a2's Avatar
A friend has one on his 07, 5.9 and his only complaint are the sky high egts. 1,400 degrees is pretty easy and thats only towing 7,000 pounds. If you want safe egt's get a smarty. Amazing product.
Old Jun 26, 2012 | 05:51 PM
Falcon1's Avatar
You need to dump that little turbo to gey control of your egt's
5.0 Mustang Man
Oct 21, 2008 02:50 PM
razor6
22
Jan 20, 2006 03:43 PM
PThree
22
Feb 14, 2005 11:11 AM
john@dps
19
Dec 30, 2004 07:10 PM
Big Bob
Dec 24, 2004 04:10 PM
