Edge Juice, low boost numbers
Old Mar 24, 2006 | 02:59 PM
Capp35's Avatar
I have an Edge Juice without the Attitude monitor.
The only reason I would get it (besides the high EGT defueling), is the adjustable low boost fueling.
Can someone tell me the difference between level 3 low boost (default setting) and level 5 low boost fueling?
Any numbers or seat of the pants feelings would be appreciated.
Thanks.
Old Mar 24, 2006 | 10:43 PM
Capp35's Avatar
All the people that have a Juice/Att. and no one can answer?
Old Mar 25, 2006 | 09:19 AM
Lightman's Avatar
If you get the attitude you will also pick up 20 more horsepower I believe, the standard juice doesn't allow the same power levels.
Switching low boost fuelling to the higher level should get you a little more bottom end power accompanied by more smoke.
Old Mar 25, 2006 | 02:09 PM
Argo's Avatar
The difference is noticeable on tackoff and on the fuel gauge if you like to gunn it all the time. I keep my level 1 at 3, level 2 at 3, level 3 at 4, level 4 at 5 and level 5 at 5. I never use level 5 on my hot juice. Level 4 is plenty of power for my taste. My juice shows me at just over a 15 quarter so going by what most experience in real world on the track i am probably mid 14 with that as the only upgrad other than a drop in AFE filter. That is on level 4.
Old Mar 26, 2006 | 12:39 PM
Capp35's Avatar
Thanks.
I may try to find one used, since alot of people are upgrading to the A2.
Old Mar 26, 2006 | 12:43 PM
swansong04's Avatar
i was wondering that myself ?? are guys really upgrading to the a2 ?? it is freaking expensive .. and you can buy a sweet !! stand alone gps unit and still have money in your pocket ...
G
sCreamin400
Nov 2, 2008 01:46 PM
Lionhart75
Aug 16, 2007 07:32 PM
65fury
Jun 7, 2007 08:08 PM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
