edge ez and juice stack
Old May 31, 2006 | 12:10 PM
blh1972's Avatar
Question edge ez and juice stack
Does anyone have dyno numbers from running this stack?
Thanks guys.
Old May 31, 2006 | 12:37 PM
RamWheelsBy4's Avatar
Well with the FASS and SPS66 turbo, the HOT Juice/Attitude & EZ stack dyno'd around 480rwhp. With stock LP and turbo the standard Juice dyno'd around 370rwhp. I would guess the EZ might add 20-30rwhp or so. I would guess around 400rwhp at best with what you show in your signature. Just a guess.
Old May 31, 2006 | 08:01 PM
OT-OF-Here's Avatar
Juice/EZ stack
Thanks guys.
Early on I ran that stack. I had a FASS, Intake, Exhaust. I ran 435hp and 868 tq.
Old Jun 1, 2006 | 12:32 PM
blh1972's Avatar
Question ?
The reason I ask is because I am thinking of selling my quad for the juice. I have the race box stacked with the ez now with no problems, but don't want to tear anything up. I would eventually like to be close to 500hp. Any suggestions?
Old Jun 1, 2006 | 03:35 PM
OT-OF-Here's Avatar
Suggestion
Yes, I have a suggestion. Only if you have the supporting cast of upgrades to accompany it,... go with the HOT Juice/EZ stack and you'll be real close with the FASS, Air intake and Exh.
Old Jun 1, 2006 | 04:35 PM
blh1972's Avatar
Talking thanks
Thanks ot-o-here, Thats pretty much what I wanted to hear.
Old Jun 1, 2006 | 11:27 PM
973604x4's Avatar
Will the stock turbo be enough? i ordered an EZ today to stack with my Juice. I was afraid the HOT juice would be too much for the stock turbo.
Old Jun 2, 2006 | 05:33 AM
OT-OF-Here's Avatar
Flame out!!
There will of course be tons of guys to disagree with me on this issue,... but it depends on what you use your truck for. If you just pull light weight then it will probably work just fine,.... if your not all over it all the time then it will probably work fine for that also. I ran that setup with the stocker and it was a really nice setup for an occassional romp. If your talking wot runs up to 100 and more then it's not for you,... egts will be too high and the turbo probably won't hold up. Generally when it comes to turbos you can't have it all. The bigger the turbo the better the cooling but the more the lag especially if the exh side is say larger than 12cm. My $.02.
Old Jun 3, 2006 | 05:26 PM
973604x4's Avatar
OT-OF-HERE-
Thanks for your opinion. I like to romp mine... a lot. I run the quarter mile a lot and always love to accelerate fast. I won't upgrade to the HOT juice, but my EZ is on order. It will be stacked with my Juice for now until I can get a turbo. I planned to get an HTB2 but decided to hold on to the cash for a while.
white250005
Oct 25, 2007 10:19 PM
Djasik
Sep 10, 2007 12:51 AM
VikingDiesel
Nov 15, 2006 12:24 AM
razor6
22
Jan 20, 2006 03:43 PM
