Edge EZ
Old Feb 23, 2008 | 11:47 PM
Boomchadda's Avatar
Edge EZ
I have the Edge hot juice with the attitude monitor and wanted to know if I could stack it with the Edge EZ box to raise my pressure in the fuel rail?
Old Feb 24, 2008 | 02:45 AM
White97GTVert's Avatar
What year is your truck? Fill out your signature so people can make good recommendations.
If you have an 04.5 or later then yes the EZ stacks very nicely with the Juice.
However, you may have fuel pressure issues running that if you are still on the stock lift pump.
If the truck is a 03/early 04 then the answer is proably no since those years the Juice already had added pressure and the EZ will probably be too much..
I ran the Hot Juice/EZ stack for a while and it was nice.
Old Feb 24, 2008 | 04:18 AM
Boomchadda's Avatar
i have an 06 and a htb2 turbo 90 horse injectors airdog 150 stage 2 floor it cp3 pump ats exhaust manifold, cfm intake manifold, aem bruteforce intake and hot juice with attitude. will the edge ez box work good with my setup?
Old Feb 24, 2008 | 10:43 AM
Absolutely. You'll love it. Usually ran mine on 1 or 2 to keep pressures from potentially cracking the injector bodies. Back when I ran it we had to estimate rail pressure because a gauge wasn't yet available. The Pricol gauge had just come out but was pretty expensive so I don't know what the actual RP was it felt really good with the EZ on 2.
Old Feb 24, 2008 | 02:41 PM
Boomchadda's Avatar
thank you.. haha just noticed that I have the same turbo as you.. thanks again..
jwhip
28
May 29, 2005 11:32 AM
rockjeep73
Mar 25, 2005 03:34 AM
Hoss
13
Jun 18, 2004 06:14 PM
powerwagon440
Jan 20, 2003 08:50 PM
