Easiest way to go 2 micron filtering?
I run the kit I posted above in series with the factory fuel filter and push fuel with the factory in-tank lift pump. Even with my 100 h.p. Quad Std. module I haven't had a problem. I get too hot before I run out of fuel.
No doubt its going to run and operate ok but its not an ideal setup and will have better results if you to run a better pump.
Im waiting to do all four, pump, filter, big lines, and vent kit all at once.
I like the idea of the fuel boss but it wont work with fluidampers.
I have been running the GDP 2 micron kit with the stock lift pump for about 15,000 miles with no problems. I have a FP gauge post filter and see about 9-10 psi at idle. Normal driving pulls it down to about 7-8 psi which I think is pretty safe regarding the CP3. I still want to get the walbro kit just for the reliability.
Mike
Mike
03RAM2500
Jan 11, 2009 05:21 PM
Gman_dodge
Sep 6, 2007 03:27 PM
Bookshelf
Mar 25, 2007 09:12 AM
TxDiesel007
Nov 22, 2006 08:27 PM
