Easiest way to get oil in ur NV4500
Old Nov 22, 2006 | 01:22 PM
TxDiesel007's Avatar
Guys,
what is the easiest way? I like using those little siphon pumps with hoses on both ends, BUT they keep busting on me after the first or second use..
Does anyone know any other easier way?
Thanks guys!
Rick
Old Nov 22, 2006 | 01:36 PM
displacedtexan's Avatar
I have a Mity-Vac, it swaped the tranny fluid for me, and flushed my brake system, and is holding up fine. I have the plastic one, but they also make a metal version.
http://www.mityvac.com/
Old Nov 22, 2006 | 04:13 PM
Tate's Avatar
Piece of clear hose stuck to a funnel, and lots of patience.
Old Nov 22, 2006 | 04:15 PM
I didn't have near enough patience. Did one fill of the funel, went to the parts store to get the Mity-Vac
Old Nov 22, 2006 | 06:04 PM
Christmas for me will come early
time to get me one of them.... and bout the piece of hose? NO PATIENCE.. no yelling intended...
Rick
Old Nov 22, 2006 | 06:37 PM
infidel's Avatar
I buy my Syntorx in gallon jugs here http://www.standardtransmission.com/dodge.html
This $6 pump is designed for pumping thick anti-flat tire sealing gel, easily pumps even 90w and screws right on to the top of most all gallon jugs, does about half a cup per stroke. Been using the same pump for at least seven years on differentials, transfer cases and trannies.
http://www.gemplers.com/a/shop/produ...31520621102214
The hand transfer pumps from the autoparts are a pain to clean out and if you aren't watching out easily tip over the container you're pumping out of making an expensive mess.
Old Nov 22, 2006 | 08:19 PM
wildmanben's Avatar
take the shift tower off and pour it in!
Old Nov 22, 2006 | 08:27 PM
I with you Rick, patience is a quality I greatly admire, but don't possess much of
APD
Jul 25, 2014 10:38 AM
jmccart
20
Oct 30, 2007 08:41 PM
glenn9898
Oct 5, 2007 12:04 PM
Gman_dodge
Sep 6, 2007 03:27 PM
Bookshelf
Mar 25, 2007 09:12 AM
