dum question for the day
Old Sep 7, 2007 | 07:12 PM
pala's Avatar
got my new mbrp muffler today.
which way does it go on.
there are louvers on the inside of it, im thinkin the open part of the louvers go towards the turbo
besides that , it dont seem long enough, it measures 30inch but my stock is way longer.
comments, thx in adavance
Old Sep 7, 2007 | 07:24 PM
haildog's Avatar
Open end of the louvers away from the turbo.
Old Sep 7, 2007 | 07:35 PM
Raspy's Avatar
Yes, open louvers away from the turbo. Less restriction that way.
John
Old Sep 8, 2007 | 01:18 PM
PEAKSTRYDE's Avatar
X3 for the louvers.
Did you get the extra pipe with it to replace the stocker??????
If you only got the muffler then you are going to have to get another piece to fit it together.
Yes you are right the muffler itself is to short to replace the OEM.
Old Sep 9, 2007 | 10:10 AM
Raspy's Avatar
You can always run the pipe out in front of the wheel instead of behind it. That's what I did and it is very nice. Sounds better, eliminates five feet of pipe, no interference with the spare, stops the black bumper problem and makes room for an air tank.
To do it I moved my MBRP muffler about 3 feet forward, then pieced the tail pipe together with 2 pieces. One turns slightly down and out toward the side and the next turns back to level and on out. Slip on the tip attach the hangars and you're done. Well worth it!
There is a small turn up in the frame near the spring mount. That's the place to turn out. It looks really cool coming out the side like that and the sound is music.
John
Old Sep 10, 2007 | 07:30 AM
farmboykjb5.9's Avatar
I have my own 5 inch straight through no muffler did it myself coming out in front of the tire and if i feel like using my power and get on it a lot my rim gets covered black all the time and its a pain in the *** to get it clean.
Old Sep 10, 2007 | 08:24 AM
SSminnow's Avatar
Putting the "ends up" toward the turbo will chang the sound as well, will gve you more "flutter". My friend did i, as were just curious if therewould be sounds difference. Also, I am not arguing the fact that it hurts flow (maybe it does, maybe it doesn't) but there was no "seat of the pants" difference for sure.
Old Sep 10, 2007 | 08:36 AM
RoadRacer's Avatar
Originally Posted by PEAKSTRYDE
X3 for the louvers.
HMMMMMMMMM,strange.I have asked someone that everyone says this is the man to deal with and he said it "will bolt right up".Maybe he meant,"it will bolt right up to one end"HMMMMMMMMM,strange.
redcad
Dec 6, 2007 11:21 AM
kingofdodge7131
May 19, 2006 11:07 AM
2500TurboDodge
Apr 7, 2005 01:49 PM
Trusty Steed
Jan 9, 2004 09:13 PM
