Duel feed on CP3 fuel pump leaking
Hello
I’m new to the diesel seen just bought a 2005 Ram with about 80K on it. Owned it for a few mounts now and I love it. When I bought the truck I knew there had been some mods done to it, runs much better than the stockers I test drove. At any rate my truck has a duel feed kit on the CP3 fuel pump and a few weeks ago the plastic duel feed line started leaking at the fittings on both ends. I would just replace the line but since it is has suddenly started leaking at both ends I wondering if there is an over pressure issue since the duel feed kit removes the over presser check valve.
Does any one have any experience with this duel feed system?
Any one with a similar issue out there?
I suspect that my truck has had larger injectors installed due to the ARP head studs, FASS lift pump, and a few other tells under the hood. Using my highly calibrated seat dyno I am guessing 50 to 100hp injectors.
I am not sure if the fuel pump has been moded.
Any help would be appreciated.
By the way this site rocks I have learned a ton in just a few days of reading your past post thank you all.
Regards
Regards
when you blow through a couple you'll see that they only have a plastic coating. It's actually woven steel on the inside with a plastic coating over it.
II was really good about fixing me up with a hose when mine started leaking. They are well aware of the problems with the older gray hoses.
Talked with I.I. They told me that the issue with a few of the Gray lines was bad crimps on the fittings but that was only one batch. They warranty the product for one year and they have been selling the blue lines for over a year, so mine is out of the warranty period. Since mine is leaking at the fittings they suggested loosing & retightened. I tried that. I even took the line off to inspect the fittings; they looked okay to me. No big gouges or any thing that looked like a definitive leak path. I asked if there was the torque spec, they guy said tight, and mine are & it is still leaking. I would just buy a new line ($175.00 from II) but I am worried about the real issue being an over pressure thing since the duel feed line removes the over pressure valve from the rail. Can the pump malfunction and default to a high-pressure condition? I would think that it would throw a code and light up the check engine light if it was in some default mode and my light is not lit. I could take a chance and throw a new line at it but I find it very odd that it leaks at the fitting on both ends. Seems like pressure is high and these just happen to be the weak points in the system.
Any one with some insight out there?
That is BS if II knows they had a problem and they're not going to take care of it!!! This is just another reason I've heard of to NOT buy their products! I hope mine never leaks or they will have a !@#$%^ problem on their hands
I ordered a new kit from II. They did give me a price break since I already had a kit. They could not warrantee it since I did not buy it. It was on the truck when I bought it. And it was out of warrantee any way. So I though that was fair. However make sure you inspect your parts. they sent me 3 before I got good parts. The first was missing a fitting and there were tool marks from machining on one fitting so it is unlikely it would seal also there was rust on the inside of the line. So I called II and they shipped me a new kit next day air. This one was complete but again there was rust in the line. I called again and sent them pictures. They next dayed a new line. The third line was good. Installed it on the truck and it seems to have fixed the problem. I have been driving it for 3 days now with no leaks. While there were parts issues I still feel II treated me okay, seems like they maybe sorting through some supplier issues or some thing but when I called it was pretty much no questions and they sent replacement parts next day so over all it was a good deal. That being said this kit seems pretty pricey I wonder how much Parker charges for this line? Hmmm maybe we will have to look into that.
I wonder if Parker is installing the fittings, we could contact them and see if they will stand behind their product since II will not. If they sent you 2 rusty lines and a total of 3 bad kits??? Sounds like they're to worried about CP3 performance to inspect product before it leaves. I know of a pretty big II dealer who's also less then impressed w/ their products and customer service lately.
Get something else.
