DR-Performance
they keep telling me the first thing to go is memory. i forgot the name i will check it out tomorrow if i can. i know it is just a plug in device that they say will help mpg, hp, tq, the usual. it also claims to do this through fuel atomization say it helps the life of the engine. i know this is more than likely the typical advertising mumbo jumbo. price is around 450 oh and has a **** with three levels. i was really wanting something that i could calibrate speedo with and clearing dtc is nice. i have gauges so i don't need one like that. and to be honest i'm a little nervous about the edge i've seen quite a few posts on here with troubles. what about the ts/mp8? i know it doesn't do the speedo and dtc.
Originally Posted by roc155
kaboom because of the dr.performance
Dr.P
I have the 100hp 250trq Dr.P so far no problems ran it in my 04.5 also with no problems put about 36,000 miles on it now its in my 06 and still runs good only 4,000 miles so far I still worry about the longivity of these boxes its a fuel box and the power is incredible. I usualy lay off the throttle but i know its there when i need it.. I am running no guages at this time just not in my budget as of yet hopefully some day will get a guage and see whats going on with it..I think I am going to pick up a defuel guage I called Dr.P and they want $800.00 for the parimeter and the built in brake module very hefty price..
i've had a stage 2 on for 17000 miles so far. No problems and great mileage. If I need it, the 100hp setting makes my truck really move. on the 50hp mode I can't get my EGT's above 1200* unless I'm pedal down on a really steep grade. on the 100hp setting I can barely break 1300* on level ground
I keep it on the 50hp setting 95% of the time and I can't complain, no signs of bad things happening.
my stage two is not adjustable. do they make something that i can hook up to it to adjust the power levels? i believe it is like an 85hp and 160tq. what about towing with it can you or not?
