Don't trust your overhead.
Old Mar 18, 2007 | 07:26 AM
Guardrail's Avatar
I'm running the Superchips Firefly and it really screws up the overhead MPG. The other day I was driving along and the low fuel light came on. Usually I don't let it get that low, but I was planning a trip into Missouri where the fuel was about 20 cents cheaper so I let it go.
I was driving home from work and thought to myself, "self, you'd better stop for some fuel before you get home." I punched the overhead to see how far I had until I ran out and it told me 35 miles. I don't know why I believed it, the MPG have been way off since I put the Firefly on. As soon I had punched the overhead back to the compass, the truck died and I coasted to the side of the road.
No big deal, I was only a couple of miles from the house. There was only one problem, it was 2:30 pm. Everyone I know that could help is gainfully employed and at work. My wife was able to get off work early and rescue me. I feel like a real dummy.
Old Mar 18, 2007 | 07:51 AM
InfernoB's Avatar
I'm still learning mine, but the other day it said DTE was 35, and I needed 2.5 gallons at 16 MPG. Pretty close that day. I usually only look at the trip, and base my fuel ups on that, and the needle. This time I too let the light come on. It came on 30 miles earlier.(Got to know if it works right?)
I've also found that the overhead is about 2 to 3 MPG off.
Glad you got home to remind people not to trust the Overhead.
Old Mar 18, 2007 | 08:30 PM
DODGER BOMBER's Avatar
i have had mine to 0km till empty for about 20km and stil made it to the station and left it runnin while i got the pump activated at the cardlock. I dont know but some times electronics can be wrong.
Old Mar 18, 2007 | 09:06 PM
95ram's Avatar
My overhead is off by 2-3 MPG. That thing is worthless.
Old Mar 18, 2007 | 09:13 PM
t-boe's Avatar
I only use mine to get a general idea of how I'm doing between fillups. Mine's usually off about 1-3 mpg. If it's all highway it's off by about 1 mpg. All city, it can be way off.
Old Mar 18, 2007 | 09:23 PM
boarbuster's Avatar
My gauge decides when i fill up. When it starts bouncing on the peg it is getting pretty close to the time i need to fill up. That being said i am below the red right now.
Old Mar 18, 2007 | 10:04 PM
skynyrd's Avatar
i have ran my over head til 8 miles DTE. but i tend to watch my fuel pressure gauge at those numbers and you could see the pressure starting to drop down when giving it throttle. so if you have a fuel pressure gauge it helps to see when your starting to run out of fuel cause your pressure drops to 0.
Old Mar 18, 2007 | 10:15 PM
dodge2005's Avatar
Mine is usually off as well. Even though I can count on one hand how many time I have let my tank run under 1/4 tank. Knock on wood, I have never ran out of fuel. It was beaten into my head that if I have a 1/4 tank left than it was empty.
Old Mar 18, 2007 | 10:51 PM
Guardrail's Avatar
The overhead shows around 22 MPG. (I wish) Last I checked, I usually get around 15 city. I guess the Firefly must be throwing some bogus info to the ECM to make it calculate that high.
busa
17
Feb 26, 2008 08:42 PM
fflarry
13
Feb 3, 2008 12:43 PM
Timmay2
Jan 4, 2007 10:05 AM
slowerthanu
46
Mar 31, 2005 12:38 PM
