Does Smarty S06 Do Boost Fooling?
Old Jan 7, 2008 | 08:07 AM
Ghost Ram's Avatar
im seeing alot of guys stacking the smarty w/ a boost fooler. why is this? does the smarty add boost on a stock truck by itself or would i need to stack it w/ something or upgrade the turbo? i just got a smarty s06 the other day and havent installed it yet. i will most likely run it on sw3 or sw5, will i see more boost w/ either setting? what about higher settings?
Old Jan 7, 2008 | 08:16 AM
tcr's Avatar
tcr
yes...............
Old Jan 7, 2008 | 08:30 AM
Ghost Ram's Avatar
yes what, it adds boost or i would need to stack it. and if it adds boost, why are others stacking it w/a boost fooler on top of a stock turbo?
Old Jan 7, 2008 | 08:34 AM
haloman's Avatar
I am fairly sure you need to run the Aftermarket Turbo SW to get the boost fooling.
Old Jan 7, 2008 | 01:02 PM
rammv's Avatar
I do not think it boost fools out of the box.Just did some highway full throttle runs only hits 30# boost then drops back and forth from 28# to 30#. My superchips would hit 40 to 42 then Drop to 30# at wot runs. Am going to try after market turbo next to see if it helps.
Old Jan 7, 2008 | 04:56 PM
gus's 03's Avatar
stock smarty software retains boost limit, aftermarket turbo software alows higher boost.
its not actualy " boost fooling" its an extended bost map.... in otherwords instead of tricking the ecm into thinking it only hit 30 psi, it actualy knows what to do with the extra air...
Old Jan 7, 2008 | 05:03 PM
rammv's Avatar
Thank you that was very informative. always look forward to that kind of info. Mike
Old Jan 7, 2008 | 05:15 PM
Ghost Ram's Avatar
i just spoke w/ bob wagner and he said it does do "boost fooling" so to speak out of the box. he said it would be more noticable the higher you go in levels. he said i have the new 4.11 mild tq program.
Txwelder
Sep 20, 2009 10:17 PM
buddy26
Jan 4, 2008 12:22 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
CTD03
Jul 24, 2007 12:17 PM
goose2w1
May 25, 2007 09:36 AM
