Dodge Steering Stabilizer
Old Dec 18, 2006 | 09:16 PM
mitternocht's Avatar
Well, just bought me a DSS; that steering stabilizer that ties the frame rails together and supports a bearing for sector shaft.
I’ve never had the death wobble, but this truck has always has a slight case of the wonders. It was never enough to put you in the ditch, but just enough to be annoying and make me look like a DUI candidate.
While I was at it I threw on a Rancho 5000 steering damper too, probably not the best unit, but better than stock. The Rancho made the steering a bit stiffer; the DSS took away a lot of the wonder and gave me another grease fitting. I can’t wait for my next road trip to see how it does down the highway.
The steering boxes on these things look like it should be on a small car, not a heavy pickup truck. You can tell the bean counters were all over these things. I’m hopping the DSS will add some life to may steering box. I measured about .015” of play in the sector shaft with just light pressure on the wheel in the driveway before the DSS. I didn’t measure it after for I was too excited to drive it, however I can assure you that it is much less.
Old Dec 18, 2006 | 09:35 PM
4x4not's Avatar
This is good to know. I might get myself one of those setups....
Old Dec 19, 2006 | 09:04 AM
goodeyesniper75's Avatar
where did you get the dss from? i want to get one cuz my truck has the wonders too
Old Dec 19, 2006 | 09:06 AM
also how long did it take to put in?
Old Dec 19, 2006 | 12:02 PM
Hunter11's Avatar
I had a DSS on my old 01.5 and loved it. It was probably one of the best mods I did to that truck. It really tightened up the steering and made the truck so much easier to control. I have been thinking about adding one to my 05.
Old Dec 19, 2006 | 12:11 PM
pooperscooper's Avatar
I am looking at getting one this week if i find out this bit of informaition. I have 4 inch drop brackets for my sway bar. will they conflict with the stabalizer?
Old Dec 19, 2006 | 01:36 PM
Hunter11's Avatar
You would probably have to call Darin and ask about that.
Old Dec 19, 2006 | 03:11 PM
cquestad's Avatar
I love mine...
Source Auto has em....
Old Dec 19, 2006 | 06:10 PM
Mine came from here:
http://www.piersdiesel.com/DSS.htm
It took about 30-min to put on. Take off the old pitman arm nut, but on the new DSS nut, drop the sway bar, put the DSS unit in place, align put back up the sway bar, put the bearing and bearing retainer on, grease and you are all set. The thing even comes painted.
Old Dec 19, 2006 | 09:01 PM
sounds good.........
Old Dec 19, 2006 | 09:07 PM
djgaston's Avatar
No, they just make it a little more tricky to install it all together because of the extra pieces, but there is no interference.
mercedeezel
13
Oct 13, 2013 12:43 AM
EdmontonCanada
Jul 20, 2010 03:57 PM
1985cucv
Jul 31, 2009 02:33 AM
Rattlerattle
Aug 19, 2008 04:14 PM
13ALPHA
Jul 8, 2008 11:31 PM
