differences between 05 and 06 2500???
Old Oct 27, 2008 | 11:24 AM
hotrod929's Avatar
I am looking at ether one of these trucks and was wondering if there was any big differences between the two as far as engin and drive train? Any pros/cons to ether when modding? THanks
HotRod
Old Oct 27, 2008 | 11:33 AM
HOV's Avatar
HOV
The 2006 automatic transmission will have two major upgrades over the 2005:
1) Tow haul mode AND O/D lockout
2) Exhaust brake compatibility
IIRC, the 2005 motors are rated at 305HP and 555TQ; the 2006 motors are 325HP and 610TQ.
The 2006 also has an upated interior. I happen to like it a lot but I know many prefer the older style.
Finally, the 2006 offerings include the Megacab. That wasn't available previously.
Old Oct 27, 2008 | 12:02 PM
hotrod929's Avatar
Thanks I will actually be looking at a 6 speed QC long bed.
Thanks
HotRod
Old Oct 27, 2008 | 12:13 PM
moparmatt's Avatar
2005 would be the 325 600 series motor
Old Oct 27, 2008 | 01:00 PM
Easy_C's Avatar
The biggest thing I like is the head lights on the 06. I had a 02 before... I can actually see at night now! A little too well though. They're so bright... especially with the driving lights on... I get high beamed a lot because people think they are my high beams
Old Oct 27, 2008 | 02:47 PM
05 Thunder Beas's Avatar
05 and 06 are identical drivetrain wise. The o/d lockout was the only difference and there is a reflash at a dealer to remedy this.
Old Oct 27, 2008 | 03:58 PM
Farmboy89's Avatar
There should be no difference, but i have an 05 and dad has an 06 that are virtually identical and he gets about 7 less mpg than i do. he runs a superchip and my only mod is a cold air box
Old Oct 27, 2008 | 04:22 PM
CrashCade's Avatar
Drivetrain is pretty much identical. The computer and electrical systems are different on the '06 that allows for some diiferent features that the '05 doesn't have. I will have to look at my PMT to remember what they are.
The reflash you are referring to changes the tranny programming completely and removes the Tow/Haul programming in exchange for OD lock out.
I have an '05 and had the chance to update the front end to an '06+ and love the looks.
Also, I like the '05 interior a lot better as well. The dash looks nicer and I think the seats are more comfy. I know that stock for stock just using a BDTD w /CL that the '05 responds better than the '06.
Old Oct 27, 2008 | 06:56 PM
Big Blue24's Avatar
Half of the 05's out there also came with a plastic end-cap charge air cooler "intercooler" that seems to not like high boost for miles and miles like the all aluminum ones.
Old Oct 28, 2008 | 12:36 AM
fuelmiser's Avatar
Early 05's dont have the g56. g56 is suppose to be better, but the dual mass flywheel is a problem. Build date 06/06 had issues with excessive egt's with tst chips. I think most of the others work.
Old Oct 28, 2008 | 07:43 AM
jrussell's Avatar
If you plan on modding it, check the '06 to see if it's an '06.5. Trucks built on or after June 2006 can't run a TST or VA C5.
MikeRP
79
Nov 21, 2016 10:19 PM
jmlcolorado
Oct 18, 2011 04:27 PM
NHDiesel
Apr 29, 2005 01:22 PM
westport
Sep 23, 2003 07:15 AM
Dan C.
Aug 12, 2003 07:45 AM
