difference between phat shaft and silver bullet
Old Aug 3, 2007 | 08:11 PM
dodgecowboy04.5's Avatar
What is the difference between the II Phat Shaft and the Silver Bullet turbos.
About the only difference i can tell is the price. I am thinking about buying one or the other, which one should i choose
Old Aug 3, 2007 | 08:26 PM
WUnderwood's Avatar
the wheels, the exhaust housing, and the polished compressor housing, might want to call II to make sure, but I think I am close
Old Aug 3, 2007 | 08:32 PM
Mighty Goat's Avatar
The SPS's have a 71mm wheel where as the Silver Bullet has a 74mm wheel. Other than that, the S.B. is polished as noted above.
Old Aug 3, 2007 | 09:08 PM
trik396's Avatar
71mm vs 74mm is correct. If you're going to be mildly modifyed with fueling I'd say go with the sp or sps turbo. If you're going to be pushing some fuel, go with the silver series of turbos.
Old Aug 3, 2007 | 09:15 PM
morkable's Avatar
You are right on the money trik
Kevin
Old Aug 4, 2007 | 08:07 AM
wap's Avatar
wap
I really want to have my 66 turned into a SB but I dont know how much it will help.
Anybody on here ever when from a standard SPS 6? to a Silver 6?
Old Aug 4, 2007 | 09:30 AM
king d's Avatar
my phat shaft has seen some pretty decent hp and is livig pretty good so far.
Old Aug 4, 2007 | 01:17 PM
PourinDiesel's Avatar
Remember the 71mm vs. 74mm thing people are mentioning with the Phat Shafts and SB's is the turbine wheel.
If you really want a true 71mm compressor turbo get an Aurora 5000 it has the 71mm up front and a 76mm in the rear...
Old Aug 4, 2007 | 05:11 PM
I still want to use the truck for towing so which of the phat shaft series would best suit with out doing damage
Old Aug 7, 2007 | 02:34 AM
jwb600's Avatar
62 or 64 I would say. Ive ran the 66 and it was not something I would try to haul heavy stuff with. it surged just as much as an aurora 5k does now
Hillbilly Delux
May 3, 2013 08:35 PM
OldSmokey
16
Nov 26, 2007 09:44 PM
GLHS
27
Nov 23, 2007 11:12 AM
Smkn600CTD
33
May 28, 2007 09:50 AM
4x4dually
Jan 5, 2007 01:07 PM
