Denver, lifted truck avail?
Old Aug 17, 2006 | 08:01 AM
RockcrawlingTJ's Avatar
I am in tne Denver area and do not know anyone with a lifted 3rd gen Ram. Anyone in the area have a 4" - 6" lift on their truck mind getting together so I can check a few things out on the truck as well as see the ride quality?
I am on the fence about lifting my truck. I am not new to the 4x4 industry or lifted vehicles (I customize suspensions for jeeps and Yota's mainly - http://i9.photobucket.com/albums/a74...J/f30eafee.jpg. I have not ridden in a lifted 3rd gen so I am unsure of the handling or ride characteristics for this truck.
Thanks.
Justin
Old Aug 17, 2006 | 10:07 AM
cquestad's Avatar
Um...they handle great...
Go for 4.5 inch...the "right" wheels and 37's with4:10's. Sweet sweet set up.
Old Aug 17, 2006 | 11:12 AM
cquestad:
I take it your Tuff Country lift is the short arms? New rear springs or blocks? Did you put an anti-wrap bar in the rear?
I have heard multiple takes on the lift, from great ride to shatty ride. Hence the request to actually ride in a lifted rig.
Old Aug 17, 2006 | 11:51 AM
cquestad's Avatar
IMHO...long arms are not needed with only 4.5" of lift. The ride is great...same as stock...cause the springs are stock! Jounce is controlled by Bilsteen 5100's which are far superior to OEM or other big box lift kit shocks.
I have not needed ladder bars...have minimal spring wrap. But I will have a 3rd member mounted above the driveline "ladder" or anti wrap bar soon...I just have to remember to order my joints...LOL.
Old Aug 17, 2006 | 12:34 PM
So let me get this straight - the Tuff Country lift uses 4.5" pucks for the front coils and lift blocks for the rear?
Bilsteen's are good shocks for sure...
Old Aug 17, 2006 | 12:48 PM
cquestad's Avatar
If you call bolted steel spacers pucks...then yes.
Go to their website or www.suspensionconnection.com to see the components.
This is not a "race" level quality kit, but works excellent for those who work their truck. 100k of highway, city, drags, hauls, hunting, camping, climbing, pulling...etc.
Old Aug 17, 2006 | 02:22 PM
Huh... I've never used pucks/plates over 2". I don't see bump-stop extensions in their kit? Are the coils retained by the pucks in any way?
Old Aug 17, 2006 | 03:50 PM
cquestad's Avatar
Yes...they are centered in a similar fashion as the OEM perch. The height of a coil spring spacer does not matter within reason...they are only in compression...no side load. I have 100k with no alignment issues (only aligned once at 10k when I installed the lift), balljoints, suspension breakage or failure, poor tire wear, squeaks, etc. It has served and is still serving it's purpose well. No sag...and a plush ride. I may be up for some new shocks soon...maybe brake pads too....but everything else is still kicking butt.
Old Aug 17, 2006 | 04:12 PM
I appreciate the information - would still like to ride in a lifted rig just to feel it... Anyone?
Justin
Old Aug 17, 2006 | 08:42 PM
rockhound's Avatar
nobody wants to talk to you
call me we can chase away our tatebuds over some hot wings
Old Aug 18, 2006 | 09:07 AM
nriver's Avatar
if you were around Portland OR or SW Wash I could help. Just thought i would post to see what comes of your request.
good luck
Old Aug 18, 2006 | 09:16 AM
Thanks... Still searching.
jgiachino
15
Jan 21, 2010 10:48 PM
Grocery Getter
36
Jul 30, 2007 05:31 PM
popeyesides
Apr 26, 2006 12:00 AM
Copenhagenjunkie
Feb 22, 2006 03:45 PM
