Creating twins with stock turbo
Old May 30, 2008 | 07:21 PM
dbossdiesel's Avatar
Cool Creating twins with stock turbo
Just wondering if i where to fab a twin set up using a stock turbo, What size turbo would I use for the secondary? Just a curious question! Thanks!
Old May 30, 2008 | 07:29 PM
Erik@LCD's Avatar
I may be putting together a set with a stock 05 turbo and an HT3B. A little old skool, but it should work for playing and towing. I'll document it if I ever get around to it...
Old May 30, 2008 | 07:34 PM
Hey thanks! I'll do some research on it!
Old May 30, 2008 | 11:03 PM
jaredb900rr's Avatar
Several people on here have used the stocker over an S400. If you're at higher elevation or tow frequently, I recommend going with the 74mm wheel over the 80mm wheel in the S400.
Old May 31, 2008 | 02:14 PM
omaharam's Avatar
Yes. 74mm with the stocker.
Old May 31, 2008 | 04:01 PM
Gary Emerald's Avatar
yeah, an 80mm would be a considerable mismatch.
nothing wrong w/ the old 3B!!!
Old May 31, 2008 | 06:15 PM
I really appreciate the responces! Cheers
Old May 31, 2008 | 09:18 PM
OutOfSight's Avatar
I have a stocker with a 74, I plan on running an 11.80 at the track for my next visit with them on fuel. They spool great, I love them!
Old May 31, 2008 | 09:27 PM
AH64ID's Avatar
So the stocker is the first turbo, then the second?
Do you have to add a mech wastegate to the stocker?
Old May 31, 2008 | 09:36 PM
OutOfSight's Avatar
You mean second turbo? Its an S400 or a B2 (same thing)
Old May 31, 2008 | 10:29 PM
AH64ID's Avatar
Yeah, isn't the goal to have a smaller quick spooling turbo feed a larger turbo?
So you get stock like spooling with better high end boost and air right?
Old May 31, 2008 | 10:45 PM
Big Blue24's Avatar
Commonly: The top turbo/smaller turbo is referred to as the secondary turbo. The bottom /larger turbo is referred to as the primary turbo.
Air is pulled through the air cleaner, into the large primary turbo, compressed, sent up a "cold pipe" to the inlet of the top/smaller/secondary turbo, compressed some more, then sent out/down another cold pipe to the CAC=Charge Air Cooler also incorrectly known as an intercooler, then fed into the engine through the air horn into the intake manifold where it is distributed into each cylinder as it passed through two intake valves per cylinder.
Commonly: Exhaust is fed from the exhaust manifold directly into the smaller/top/secondary turbo, then out the turbine housing into a "hot pipe" 3-4" in size and into the larger/lower/primary turbo's turbine housing inlet.
Old May 31, 2008 | 10:46 PM
OK! Dumb question! What exactly are you measuring when it come to 75mm etc? I know, I know I should know this but I'm having a brain cramp! LOL
Old May 31, 2008 | 11:05 PM
inducer diameter of the compressor wheel
Old May 31, 2008 | 11:09 PM
AH64ID's Avatar
Thanks... so since the top turbo gets the exhaust first and the air second it really can compress it.
Makes me want towing twins, even on a mostly stock truck
