CP3 mod ?...again
Old Sep 4, 2007 | 09:23 AM
goodeyesniper75's Avatar
CP3 mod ?...again
Today i should be getting my spare FCA and was wondering....what if i just did the FCA first then finished the other part another time? any adverse effects?
Old Sep 4, 2007 | 09:28 AM
soulezoo's Avatar
DTR 1st Sergeant
None whatsoever! I've been running like that now for a couple of weeks. How much did the FCA run ya?
Old Sep 4, 2007 | 09:46 AM
like $90 plus shipping...how do you feel about the mod? did you notice anything?
Old Sep 4, 2007 | 10:05 AM
tesla440's Avatar
I reworked my FCA only. No problems. The low end power is great. Boost come on alot earlier & quicker. I also noticed my boost sits at 7psi at 70mph where before it would be 3-5psi. I'm checking to see if this help my mpgs any. If not it'll be up for sale.
Old Sep 4, 2007 | 10:11 AM
sounds good...i just took my spare one apart and i will be cutting it up tonight hopefully.
Old Sep 4, 2007 | 10:25 AM
soulezoo's Avatar
DTR 1st Sergeant
There is really nothing I could measure (like comparing before/after on a dyno) to tell me anything definitive. For most regular driving I saw no difference at all. The only difference I saw was on WOT runs. More smoke, faster spool, higher spool and power seemed to stay on longer meaning I was probably draining the rails before. This is all in conjunction with the lift pump upgrade too.
Old Sep 4, 2007 | 10:26 AM
soulezoo's Avatar
DTR 1st Sergeant
BTW-- + shipping? You didn't get it from the dealier then? Where did you source it?
Old Sep 4, 2007 | 10:33 AM
i went on the cummins site and looked up parts dealers. just gave them my part # and it was here the next day.
Old Sep 4, 2007 | 10:34 AM
well i just cut my FCA took about 2 mins on each side. what did you guys use to de-bur?
Old Sep 4, 2007 | 10:43 AM
soulezoo's Avatar
DTR 1st Sergeant
on the inside I used finest burr tool for the dremel I could get. On outside I used polishing wheel and compound and cleaned thoroughly afterward.
Old Sep 4, 2007 | 11:08 AM
82NDSNPR's Avatar
fca????? need info please have no clue what that part is
Old Sep 4, 2007 | 11:18 AM
its where the fuel comes into the cp3...by enlarging it and one other thing its basically a DIY stage 1 mod.
Old Sep 4, 2007 | 11:32 AM
omaharam's Avatar
I wouldn't term that as such. My stage 1 cp3 is much more extensive than elarging the passages of the fca.
Also, I was told just doing the fca gains very minimal. You need to modify the rotor housing to allow it to move enough fuel through the now modded fca.
Old Sep 4, 2007 | 11:38 AM
yes.....your correct...
Old Sep 4, 2007 | 12:39 PM
82NDSNPR's Avatar
k good to know i am going with a stage 3 cp3 so this does not need to be done in my case thanks for the info
