Computer codes with Predator
Old Jan 15, 2007 | 03:21 PM
texgunner's Avatar
I have a Predator programmer, when I load the Performance tune, it causes the Brake light and ABS light to come on and stay on continuously-not the 2 minutes they expect. If I look at the codes through the programmer, it shows something like "computer program missing" or something to that effect. It stays that way if I put the stock program back, but if I load the tow program, it will work fine, with that tune or back to stock once again.
The tech person I spoke to at DiabloSport said I just got a brake problem coincidentally with loading the program, he thinks there's nothing wrong with the programmer or code it is loading. I don't think that is the case.
Has anyone else had any issues like this, or had any help from Diablo? If you have a name of a good tech there, I would appreciate it.
thanks
-JR
Old Jan 15, 2007 | 03:40 PM
973604x4's Avatar
thanks
-JR
what year is the truck?
Old Jan 15, 2007 | 04:03 PM
texgunner's Avatar
Sorry, it's an 04 3500 6 speed HO.
Old Jan 15, 2007 | 04:04 PM
973604x4's Avatar
i'd say diablo is full of it too. I dunno what else to tell you.
Old Jan 15, 2007 | 09:34 PM
froggy69's Avatar
had the same brake light prob with my bro's 05,we ended up updating the programmer from diablo's website and reinstalling ,so far so good.he didn't have this problem until he borrowed a friends bullydog to see how it worked.
hope this helps
Old Jan 15, 2007 | 10:42 PM
texgunner's Avatar
Thanks, I'll see about doing that. Hope that will do the trick.
-JR
Old Jan 16, 2007 | 03:28 AM
morkable's Avatar
I had that problem with my bullydog before. but never with the predator, when it used to do it on the bd I would just program it to stock, cycle the key 3 times (checking codes) then start the truck, turn it off, and then reinstall, usually worked
Kevin
Old Jan 16, 2007 | 05:29 AM
rich2500's Avatar
had the same problem tex,try this, return to stock then disconnect the batteries and turn on the headlights(this is to drain the system totally)let the truck sit for about ten minutes, turn the lights off and hook the batteries back up then reflash to whatever setting you want.this worked for me and I have not had the problem since even after reflashes,let us know if that fixes it
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
38short
Jul 20, 2007 09:55 PM
boomer
Nov 28, 2005 07:58 PM
