Commander - Water temp sensor
Originally Posted by Hunter11
Just to update, I did recheck this past weekend and I did have the blue wire tapped. I undid the tap and moved it about 1/2 down the blue wire and retapped it and I now have good boost readings. I guess the first tap did not make good contact with the wire but all is well now.
YellowZ28,
Don't get mad if he smacks the Big 4-OH number on you later!
I would have to think that it is supposed to be rated for 32psi at the bare minimum as that is what a stock truck will do. However I know of stock trucks that have popped them?
To the best of my knowledge all the ones I have heard of popping had a load on them. Maybe huge spikes in pressure unseats them. The ones I have seen do know blow up, they unseat from the sides of the intercooler itself causing leaks when under pressure.
stock03
Nov 9, 2006 11:27 PM
TPilaske
Aug 8, 2006 03:40 PM
. I'm expecting it, I have an appointment tuesday to take mine in.
