Commander install
Old Oct 22, 2007 | 09:23 PM
Homer S.'s Avatar
Commander install
Just got the quad commander and wondered what you guys with 6 speeds do with the transmission temp wire? And is there a consesus yet on whether to leave the engine ideling while drilling the egt probe hole or not? Thanks.
Old Oct 22, 2007 | 09:26 PM
scottsjeeprolet's Avatar
don't know about the trans temp. But to do the EGT remove the pass side inner fender liner, coat the drill bit flutes with lots of grease and drill, then coat the tap with lots of grease and tap. Piece of cake.
Old Oct 22, 2007 | 09:35 PM
vzdude's Avatar
DTR's 'Go to Guy'
Leave the engine idling just like the instructions say! I have over 10K on my install with 0 troubles. I went a little extra and taped my tailpipe too. Put a small X in the middle of the tape to let out some exhaust, but the rest helped build backpressure to help blow any chips out. Take it nice and slow, and you'll be fine.
Old Oct 22, 2007 | 09:37 PM
Luvnacumns's Avatar
tAP INTO THE TOP OF THE OIL FILTER.. Actually there is all ready a plug there and run an oil temperature!! So just remove the plug and your good to go!!
Old Oct 22, 2007 | 09:40 PM
t-boe's Avatar
On a buddy's '03 we just zip tied the tranny temp up and out of the way. I've seen and drilled two different exhaust manifolds for egt and did it with the engine running with a greased bit, no problems at all.
Old Oct 22, 2007 | 10:56 PM
Seeder's Avatar
Works very well with the engine running but wear some glasses cause I had shavings shooting all over the place while I was drilling. Pilot hole helps tremendously and you can never use too much grease, piece of cake. If you tow a lot the sensor in the rear end is worth mentioning.
-Jeremy
Old Oct 23, 2007 | 03:12 AM
Homer S.'s Avatar
Turning on the exhaust brake would be like duct taping the tailpipe. Would this be advised to help get the shavings out?
Old Oct 23, 2007 | 05:38 AM
vzdude's Avatar
DTR's 'Go to Guy'
Definately! That would help, but like said above, wear safety glasses cause the chips do blow all over! I take that for granted sometimes cause I wear them almost always.
stock03
Nov 9, 2006 11:27 PM
jaredb900rr
38
Nov 6, 2006 12:09 PM
edtyler
Oct 12, 2006 03:09 AM
skydiver41
Sep 1, 2006 11:53 PM
twlunn
Aug 17, 2006 10:17 AM
