Clutch stress relief
Old Feb 9, 2011 | 07:21 PM
garr_trenching@'s Avatar
Finally, very tired of the valair shortcommings and talked to Lary here at DTR. Ordering a new Southbend setup tomorrow. Nothing worse that a sweet truck that is a pain to drive/shift.
Old Feb 9, 2011 | 07:40 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
We will get you hooked up with a high quality clutch that will meet your demands and won't break the bank at the same time Looking forward to talking with you again tomorrow
Old Feb 10, 2011 | 07:26 AM
Oliverpuller's Avatar
I will be ordering one off of Lary real soon myself. Still savin some "mad-money"!
Old Feb 10, 2011 | 08:06 PM
Rod_Montana's Avatar
A new clutch kit is in my path not too far down the road. I really like the drive-ability of the stock clutch, but she always lets loose when the boost needle trembles past 28psi and the RPM is anywhere north of 1900.
Not so eager for a South Bend though. Lot of reports on here talking about noise and shift issues, and also our local shops shy away from them because of grabby performance - not so hot for hauling livestock.
I've read somewhere about a Rhino upgrade for another 25hp and 50ft/lb of torque, but know nothing about them. Both of my experienced local shops recommend Luk and believe my stock clutch must be ailing to slip like that.
Could be. Had 10k miles on it when I bought it and the pedal always seemed to engage kinda high to me. Lived with that for 70k miles, but I think it's time to get'r done.
Old Feb 11, 2011 | 06:28 AM
tn hillbilly's Avatar
I had a Southbend OFE in my last truck, and I have one sitting here now to go in my new truck. The Southbend single disks do not make noise at all. The noise makers are dual disks, and it doesn't matter who you go with, they are going to rattle. Just the nature of the beast. As for hauling livestock, the OFE works great for it. Not grabby at all, and will hold your mods just fine. If you plan to increase your HP you are going to have to eventually go DD anyways, and then you are back to noise and rattle. Just my 2 cents worth.
Marshall
Old Feb 11, 2011 | 08:57 AM
jhenson's Avatar
I've had my Con-OFE for about 4 yrs now with no problems. Mine is very grabby if I take off in 2nd but 1st is smooth as butter.....just slow as molassas. Other than that it handles all the power my BDDL will throw at it.
Old Feb 11, 2011 | 09:22 AM
Purplezr2's Avatar
I have a south bend also, not sure what model, but it acts like this. That is the only thing I don't like about it, as I'm use to starting in 2nd when not towing. Other then that great clutch.
Old Feb 13, 2011 | 06:41 PM
railroaderone's Avatar
Love my 3250 double disk southbend not at all grabby if I pull out in low and the rattle just makes other people think its broke.
Old Feb 14, 2011 | 01:04 AM
SlowSixSpeed's Avatar
I also like my 3250 DD, but it's slow to shift but I got over that when I bought my new Shelby. My truck is now more for work then it use to be play.
Old Feb 14, 2011 | 12:45 PM
randallp84's Avatar
Marshall
I have to disagree with this statement. I have a South Bend single disc OFE and it rattles terribly. Other than that small complaint, it's a great clutch. I haven't been able to slip it yet with the Smarty set on 9 with torque management on 4. The rattle goes away at about 900rpm so it's not a big deal.
Old Nov 15, 2017 | 10:50 PM
Well, here I am six and half years later with the same factory clutch still in there. 118K miles now. It seems to have fixed itself, somehow. Maybe wearing through glazing from previous owner's abuse? I've gone from a 6k tow to a 12k tow in 2013, but she'll easily pull 30-32 boost without slipping. In fact, I can't recall the last time she did let go, but it had to be like 70k miles ago.
megajoltman
Oct 29, 2007 09:59 PM
richard
May 4, 2004 07:27 PM
apache
Apr 12, 2004 03:19 PM
Wade
Oct 9, 2002 11:49 AM
