Clutch Again!!!
its not going to be his hryo's thats just going to change peddle preasure for the most part. i had an issue like that and then all of asuddin i could no longer shift the truck the only way you could get it moving wasshut it off put it in gear and start it and it would jump forward and it was rolling. i then found out when it was takin apart that an eyebolt on the preasure plated broke so it wasnt completely disengaging they then sent me a hole new preasure plate so i bolted it in and i was good to go now it just howls a lil when taking off in 1st or second if you let the clutch out quick or down shift real hard but its not slipping at all so i can deal with it it gets pretty expensive having the shop take the thing in and out so im going to leave it.
