Clogged AFE filter? How do you guys clean them?
Old Nov 19, 2007 | 08:51 AM
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by RamWheelsBy4
Well the ProDry S will be easier to clean because it will not need oiling. I suspect since it flows a little more air than the PG 7 it will need cleaning more often. I think I paid $15 less for the ProDry S than the PG 7 filters, so there is a little savings there.
I may still switch back and forth with the PG 7 when it is time to clean the ProDry S since I have two PG 7 filters cleaned, oiled and sitting on the shelf.
This is correct. I have spoken to AFE directly and they have told me that the cleaning ability is in direct relationship to amount of flow. In filters of identical size and surface area, the standard (5 layer oiled) flows the most and filters the least. The pro-dry (what I am using now, switched from standard) is in between but does not need oiling. The PG 7 filters the most but is also most restrictive in flow and requires oiling.
With the filter minder, when the truck was stock, the minder never moved clean or dirty. (I never let it get that dirty!). When I got smarty, it would start pulling down a fair amount. I changed to an Airaid filter and the minder would barely pull again. Then boost fooler and boost elbow with smarty beta 4.4 (still stock turbo and intake) and I'd pull the minder 3/4 down. I'm simply trying to point out the relationship that extra fueling and thus more air has on that filter minder too and it is not just simply a dirty filter. Hope that helps!
The_Head
Nov 25, 2009 02:31 PM
redworm
Apr 25, 2008 02:32 PM
RockGuy82
17
Feb 13, 2007 11:22 PM
arroyojim
Nov 18, 2006 06:28 PM
bc3
Jul 21, 2006 09:33 PM
