Check engine light
Old Jan 20, 2008 | 06:43 PM
Stevemil56's Avatar
Check engine light
My check engine light came on but I have no trouble codes. What can cause the light to come on without a code. I checked the obvious things like fluid levels. Any ideas what I should check before going to the dealer?
Old Jan 20, 2008 | 08:00 PM
Billm2004's Avatar
sometimes a very short disturbance can cause it to come on, but if you drive around the problem could fix itself but the light can stay on for a while after. if you have no codes, reset the DTC light and see if it comes back on. If it does then maybe its time to check it out with the dealer, even tho you know there are going to tell you its something expensive!!
Old Jan 20, 2008 | 09:06 PM
Stevemil56's Avatar
How do you reset the light?
Old Jan 22, 2008 | 10:24 AM
Stevemil56's Avatar
I did the Key cycle to read codes and came up with two. 0633 which is no problem, but the second is 1740 which indicates a problem with the trans overdrive. I talked to the trans shop that just installed the new trans and was told that ATS is working on the problem that occurs only with California trucks. They say the trans is more efficient than the ECM thinks it should be so it flags it as a problem. No driving issues, no limp mode so I guess it is not a problem.
Old Jan 22, 2008 | 10:25 AM
Stevemil56's Avatar
BTW is there a way to clear the light without going to the dealer???
Old Jan 22, 2008 | 10:41 AM
jgiachino's Avatar
That's not uncommon with aftermarket transmissions....i've got it 3 times in 10k miles with my DTT.....i dont have a ca truck
Old Jan 22, 2008 | 10:44 AM
cincydiesel's Avatar
Just put a piece of eletrical tape over it J/K. Mine came on about a week ago with no thrown codes. Come to find out that the fuel cap was not tight. Could be something very simple
Old Jan 22, 2008 | 10:49 AM
Rammer2007's Avatar
Stevemil56, My engine light is on as well, how do you do the key cycle to read codes?
Old Jan 22, 2008 | 10:59 AM
Stevemil56's Avatar
Cycle the key off-on 3 times the odometer will display codes. I find it odd that the Bully Dog Monitor does not see the code but it appears on this test.
Old Jan 22, 2008 | 11:10 AM
Dodgezilla's Avatar
Most Downloaders will clear your codes. I'm not sure about your Bully Dog but my Predator does and so does the Smarty. Try looking in your manual for the BD....
DTT sells a voltage regulator that fools your pcm which in turn helps keep you from getting codes when you install an aftermarket trans or valvebody.
Old Jan 22, 2008 | 11:21 AM
Stevemil56's Avatar
My outlook monitor does clear codes but for some reason this code does not show up on it.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
