Catalytic Converter Removal????
Been thinking about removing the Catalytic Converter on my 04.5. Talked to a local muffler shop the guy there said he thinks he can get me a replacement pipe.
Can you remove the Cat from the exhaust on the 04.5 HO and the truck still run good or better.
Or does the engine monitor back pressure which is caused by the Cat?
Can anybody pass on any Pro's & Con's on removing the Cat?
It isn't worth the trouble if your truck isn't making over 400 hp. It'll run just fine with a differant exhaust tone. The easiest way is to take a sawzall to the pipes going to the cat and band clamp a piece of 4" pipe in it's place.
Undertaker
29
Nov 18, 2010 07:40 AM
salvagesavage
Feb 24, 2007 11:26 PM
Hummin Cummins
Apr 10, 2003 10:29 PM
