1998 dodge ram catalytic converter removal ?
Old 02-24-2007, 02:41 PM
salvagesavage's Avatar
anybody remove the catalytic converter and does it make them run better ?
better mileage ? im usually getting around 28 if drive around speed limit and good run on highway . thinking of number 10 torque plate ? what advantages and disadvantages ? are they safe ?
Old 02-24-2007, 04:18 PM
mytrucksaslug's Avatar
You know it is illegal to remove the converter. If someone were to crawl under there and find out you sawed it off with a sawzall and then replaced it with a piece of straight pipe and a couple of clamps, you could get in big trouble. And if you did violate this federal law, you would be eliminating an emmision control device that doesnt do anything whatsoever except increase back pressure which makes your engine work harder to produce the same amount of power therfore burning more fuel which increases exhaust produced therefor lowering your MPG and increasing EGT's which shortens engine life.
Old 02-24-2007, 07:35 PM
Rupenthal's Avatar
Just cut it off, most states dont do emissions inspections anyways for diesels. It will only eventually clog up and cause you more problems.
Old 02-24-2007, 08:24 PM
holeshot440's Avatar
I just bought a '98 12-valve today and it seems to be a dog compared to my '93. Do y'all think the cat (still on there) might be plugged?
Old 02-24-2007, 08:31 PM
Administrator/Jarhead
madhat's Avatar
As long as you remove it for off road use, you are good. I know a lot of guys that have off road trucks that have taken them off.
Old 02-24-2007, 11:26 PM
wcbcruzer's Avatar
All aftermarket exhaust systems don't come with a cat. I kinda wish they did myself. Cats are expensive though! $400-500 for a 5" cat.
Undertaker
29
11-18-2010 07:40 AM
GaCamper
10-25-2008 10:33 PM
Hummin Cummins
04-10-2003 10:29 PM
mymaur
12-26-2002 12:08 PM
TIM-D-FARMER
11-04-2002 11:00 AM
Quick Reply: 1998 dodge ram catalytic converter removal ?
