Can turbo come off fast?
Can you take turbo off fast with leaving manifold on or do u need to remove manifold? Are there 2 hard bolts to get or just 1? what size wrenches?
IIRC they are 15mm heads... two are bolts that will require coming from underneath and use a long extension. Two are nuts that use an open end from the top. You don't have to take off the manifold... but can make it easier to take off turbo. Be sure to let them soak in Break Free or equivalent overnight. If stuck, none are easy.
redsealdodge
31
Dec 7, 2007 05:22 PM
abc4yew
Nov 29, 2007 09:49 AM
