Can I put 33X12.50R17LT size tires on a stock rim?
Old May 27, 2005 | 04:42 PM
CTDHokie's Avatar
Question Can I put 33X12.50R17LT size tires on a stock rim?
My passenger front tire's sidewall is peeling so I am need of new tires. Does anyone know if 33X12.50R17LT will fit on our stock rims? The Cooper tires I'm looking at don't come in 285/R17.
Thanks for any help.
Old May 27, 2005 | 04:46 PM
Jeff K's Avatar
Should be no problem if guys are putting 315/70R17's on stock rims.
Old May 27, 2005 | 04:50 PM
CTDHokie's Avatar
I guess I am wondering if the metric/english part is going to matter
Old May 27, 2005 | 05:02 PM
alltimelow1's Avatar
Hey fellow CTD Hokie (class of 97)
I run Pro-Comp 33x12.5x17 Mud terrains on stock wheels - no problems whatsoever and turning 49,000 on this set, getting ready to buy another set of same I love em so much - if its pro comps you are looking at then buy them - you wont be dissapointed
Jason
Old May 27, 2005 | 08:11 PM
krock's Avatar
They will fit , but you may have some issues with tread wear ..... cupping and such .......... down the road . A 12.5 tire works better and looks a lot bigger on say a 10 " rim . And you get to put all the rubber you paid for on the ground.
Old May 28, 2005 | 12:12 AM
ricky3's Avatar
I am running 35x12.50x17 BFG Muds on my stock wheels with no sign of cupping or uneven wear. Have had them on for about 30,000 miles and love them. You can mount the 33x12.50's on the stock wheels. Make sure you maintain them just as you would any other tire...check air pressure and rotate regularly.
Old May 28, 2005 | 07:31 AM
CTDHokie's Avatar
Fellow Hokie Alltimelow1 and ricky3 do you all have alloy wheels or the steel/chrome wheels. I've got the steel/chrome ones and thought I read they were narrower then the alloys.
Old May 28, 2005 | 09:28 AM
RamWheelsBy4's Avatar
The Chrome Clad steel and the Alluminum Alloy stock wheels are both 17x8. I have a set of BFG 315/70R/17s on both.
Old May 28, 2005 | 11:32 PM
ricky3's Avatar
I have the alloy wheels.
Old May 29, 2005 | 06:33 AM
swimmy's Avatar
I just purchased a set of Toyo 285/70/R17/D Open Country A/Ts. Been on back order for many months. So far I like 'em a lot. Although they are 8 ply D rated tires, they seem to have characteristics of E rated tires in how firm they are and how little they squat. I don't know how they will wear as they are very new. These are nice tires at a good price. They look great on the 17s. You might want to check them out.
Old May 29, 2005 | 09:07 AM
surfram's Avatar
I just put 285/70/17 BFG ATs on my truck. I wanted 295 Nittos but they were back ordered for 6-8 weeks. They fit great on the stock rims with no rubbing on or offroad. They are 32.8 inches tall x 11.5 inches wide and have a weight rating of 3195lbs@65psi. The sand performance is incredibly better than the stock tires. I could go anywhere I wanted in the soft sand in the dunes of Carova Beach, NC. The beaches there are hard compacted sand but the trails leading over the dunes towards Currituck Sound have some areas where the sand looks like sugar.
Old May 30, 2005 | 02:43 PM
I have got the steel chrome ones and I think they are 17x8 - anyway they are within specs for a 12.5 tire and you WILL be able to put all the tire you paid for on the road, as I said, about 49,000 miles and no unusual wear or cupping - also, they look sweet
Old May 30, 2005 | 09:03 PM
gsbrockman's Avatar
Yes they will.......I run the LT33x12.50R17 Mastercraft Courser C/T's on my '03 and have been extremely happy with them so far (around 6,000 miles or so).
Greg
Old May 30, 2005 | 11:03 PM
bigfish's Avatar
I am looking at a set of BFG Wrangler AT/S in a 33x12.5 on a 16x10" rim. My only concern is the tire, from what i can gather from tirerack.com, is a C load rated tire good for only 2200lbs. I have seen many on this forum talk about running this size of tire. Should I be concerned about the load rating? My 265/75/16E's are rated at 3400lbs a piece right now. How is everyone getting away with a tire rated at only 2200lbs if they are putting any weight in it?
Old May 31, 2005 | 08:29 AM
nickleinonen's Avatar
i've never seen a goodyear at/s actually labled 33x12.5x16...
they have 305/70/16 and 315/70/16...
the 305 is rated at 2910, the 315 is 3085
straight from goodyears webpage
