Can 04.5 Elbow fit 04?
Well I have a Early 04 CA edition 235 and want to do my exhaust.Though I want a true 5" exhaust and need a 04.5 Exhaust Elbow.Was wondering if a 04.5 exhaust elbow would mount straight to the factory turbo?Or will I have to do something else?Will the output of the TURBO fit the INPUT of the ELBOW?or am I gonna have to go another route or what?Need help ASAP guys
You will also need a new clamp and will need to remove the indexing pins?
WHAT CLAMP?and where is the index pins?Anybody have pictures or a video of this?Don't want the muffler shop to mess up
not to hijack here, but does the 03-04.5 elbow neck down to 3.5", and then run a 3.5" downpipe? or is the necking down from 4" to 3.5" done in the downpipe? what i'm cornfused on is that i have been looking at 4" turbo back exhausts that include the downpipe, so they must mate to that elbow. are their downpipes 3.5" diameter at the elbow end and flare to 4" in the downpipe? also, what the hell is a cat back for an 03-04.5? there is no cat
The pins are in the elbow itself. There are two of them, They're small (like 1mm in diameter) on the end that connects to the turbo. They will pull right out, or you can grind them down flat if they're stuck. Look at the elbow, it's pretty apparent.
You need to pull the index pins out or the elbow will not be aimed in the right direction. Just leave everything kind of loose and get it aligned then snug it all up. I believe the new clamp you need is part #52121285aa. The clamp at the elbow /turbo is the same. You need the new downpipe/turbo clamp because it is now 4 inch not 3.5.
Totallyrad
Jul 19, 2011 07:41 AM
2006zo6pilot
Nov 29, 2007 12:48 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
